Results 1 to 10 of 10
Thread: 4AGE rwd gearbox
    Old Fart Backyard Mechanic dale30's Avatar
    Casino nsw
    Default 4AGE rwd gearbox
    I know its probably in here somewhere but i cant find it.
    What rwd box can i use behind 4age. I am going to throw a bigport into the corona and build something trick for next season..
    XT130 speedway car XT130 road car
    2 x Renault Fuego speedway cars
    02 TS50 falcon
    Light travels faster than sound. This is why some people appear bright until you hear them speak
    Default Re: 4AGE rwd gearbox
    T50 from a sprinter AE86 or corolla AE71
    T50 can also be found in TA22's but you need to use the A bellhousing
    you can use W55 / 57 / 58 but you need a custom bellhousing there are a few companies now that make A to W bellhousings
    just so u know W5# boxes are much stronger than T50's
    Junior Member Domestic Engineer MRMOPARMAN's Avatar
    vic
    a stock (or modded) bigport on dirt wont kill a t50 though, unless you like ripping gears sans clutch or running without oil. the t50 will also offer a weight advantage over a W series. t50 is the go
    well have to see what gen is better the ke30 or the ke(yuk)25
    Thats like comparing a house brick and a stiletto
    Casino nsw
    Quote Originally Posted by MRMOPARMAN
    Motor will be stock and only running 2nd gear flat out..
    T50 is that the one from KE70?
    02 TS50 falcon
    AE70/AE86... they came with 4AC
    did you try searching google for "rwd 4ag gearbox"?
    Casino nsw
    yeah but more info on here,,
    Ae70's are rare arnt they. I dont think ive seen any up here..
    02 TS50 falcon
    ke70 has k50, no dice.
    Victoria, Mt Macedon
    You can get a T50 from:
    AE86 - will bolt up, 22 output splines
    AE71 - Also bolts up, 22 output splines
    TE72 - Needs A series bellhousing, 20 or 22 outputs splines
    TA22 - Needs A series bellhousing, shifter further forward, 20 output splines
    They also came in a variety of exotic cars like SX Cressidas and so on, but they're unlikely to turn up at wreckers.
    Output splines probably wont bother you as you'll be going a custom tailshaft I guess, but something to be aware of if swapping later. As for fitting the A bellhousing to boxes, some people say it won't work and you get oil leaks, I've known other who have done it. I have no personal experience to add though.
    Hen
    vic
    ae71s also came out with a 4 speed too didnt they? if so they'd be heaps easier to find than a T50 at the wreckers, and would be a tad lighter again.
    Not that I know of. All I've seen have been 5, though that is no proof in itself.
    I've seen one 4 speed. In Mumblezzz drifter years ago, said it was from a van or something.
    Unfortunately AE71s and esp their boxes aren't easy to find at the wreckers any more. People have wised up to their usefulness.
    Hen
  1. 4AGE 100kw into AE92 (where 4AFC used to live)
    By Grega in forum Engine & Driveline Conversions
    Last Post: 24-07-2008, 05:53 PM
