Thank you for a thoughtful reply. I realize 2000rpm is way below max torque but It seems if I drop back to 3rd revs rise to 2600-2800 and fuel use goes dramatically up but the power on tap doesn't! In fact it's quite happy to cruise in OD at 2000rpm at 90kph on the freeway until a slight rise. Even a slight headwind can drop me back 2 gears.Originally Posted by hemi twofifteen turbo
It's funny, some have suggested the gas ring is at the heart of my problem and restricting everything, even petrol running, while others say it's ok. Any idea how the Impco mounts to the throttle body and would I need to change the converter?
I don't want to scrap a perfectly serviceable exhaust system for no gain so when it's had it I guess headers and bigger diameter system will go on.
As to the diff (times 2) ratio change, as you note, the same is achieved by dropping a gear however this produces no more power only revs. If I hit a hill at 80kph in 2nd gear at 5500rpm it still will be in first and 30kph by the top! It just dies in the arse.
As an experiment I will try another tank of gas in 3rd at 85kph and 2500 and watch consumption. Don't expect it to be very good tho.
I guess a turbo is looking like an option (you listening SWMBO) but I still need petrol as there's no LPG in the bush where I spend a lot of my time. I don't spose you would have any ideas of a drive in drive away cost for a turbo conversion? I probably can't afford it anyway. :-(
Thanks again for a helpful post.
Alan.
