Originally Posted by
7M-GTE MX73
Its weird that it starts better with the emanage hooked up. Is the engine significantly modified?
The cold start injector is only active when the temps are low and cranking, it would help provide fuel for initial startup but after that its inactive.
The AAV helps by bypassing air around the throttle and increases the idle when the engine is cold, this allows the engine to stabilise and warm up before idling at a lower rpm.
The AAV would help the starting and also driving while the engine is cold.
