Results 16 to 30 of 39
Thread: MA61 5me problems
    Jan 2009
    Default Re: MA61 5me problems
    anyone have a 5-me wiring diagram, i did search but i couldnt access the link for some reason.
    Team Thrash Garage's Grease Monkey VikingDrift's Avatar
    victoria
    Does it run very rough? When it runs?
    It could also be the coolant temperature sensor for the ECU (Not too hard to damage swaping engines)
    Thats where my money is. I had the same problem with an RT142, turned out the pin had fallen away inside the plastic plug casing, so it looked like it was plugged in, but wasn't making a connection Is the engine light on?? If it is just pull the code, then check that plug/sensor. Hope this helps and isn't what you'v already tried lol
    Quote Originally Posted by Mr.mx23
    Yeah I think it's worth a check!
    Check engine light on a 5me... i lol'd!
    5ME's are really basic, no check engine light!
    Wilbo's JZA80
    Wilbo's JZZ12
    victoria
    lol hey come on man i checked the engine light on a 22re, saved me heaps of time/headaches, they're basically the same motor minus 2 cylinders right?
    But...but.... some of them came out with EFI! How advanced is that!
    Quote Originally Posted by RObErT_RaTh
    All 5me's have EFI you stooge
    I have found the problem you have a 5me
    If in doubt power out
    There was an early and late 22re tho
    I wouldn't say 22re's and 5me's that basically the same either tho
    5ME is using the same efi gear that was on the MEU that came out a fair time ago now (late 70's)... it really is very basic
    Wilbo's JZA80
    Wilbo's JZZ12
    Quote Originally Posted by RONA
    Just to confirm I was referring to 5M's and not specifically 5ME's and should've payed more attention to the previous post. But here's some standard 5M linkage anywho
    http://users.tpg.com.au/users/loats/.../mhistory.html
    :: 5M
    Once again in 1980 the M engine gained a capacity increase to create the 2.8 litre 5M engine. It also received an EFI system like the 4M-E and went on to power the 1981 MA-47 Celica Supra, MS-110 Crowns, and various other JDM models.
    http://en.wikipedia.org/wiki/Toyota_M_engine
    5M
    The Bore was up again to 83.1 mm (3.27 inches) in the 2.8 L (2759 cc) 5M, produced from 1979 through 1988. Although 2-valve SOHC and carbureted versions were made, it is the fuel injected DOHC 5M-GE that is the most common.
    The SOHC engine produced just 116 hp (87 kW) at 4800 rpm and 145 ft·lbf (196 Nm) at 3600 rpm.
    In Australia the 5M-E (in 1985) was just 103 kW at 4800 rpm and 226 Nm at 3600 rpm due to the leaded petrol at the time.
    In Europe the 5M-E produced 145PS/ 107kW in Crown MS112 and CelicaSupra MA61.
    victoria
    haha yeah i meant that fairly loosely, both single cam, efi, pos
    south austraila
    Quote Originally Posted by namgnol
    i have a "Full" set of 5ME books.....
    you only need 3 x vac' hoses to run a 5ME....
    but if you have changed the wires.. then maybe you got one wrong...
    using the MA61's inlet & wires would be best..... as it is different to the others found in the crown's & cressy's.. even the 5MEU.....
    Project: '82, GA61 XX
    Quote Originally Posted by GA61XX
    that is interesting . Which ones are they ?
    Jealousy is a curse
    Quote Originally Posted by madmont
    You might only need 3x to run, but will it run just as well without the others? I'm always keen to get rid of useless crap in my engine bay
    south austraila
    Hmmmm... yep.. only 3 x vac' hoses......
    & is 240nm of torque considered as running well.??
    Yeh but you've got some diff mods compared to me, plenty more guts in there
    south austraila
    "True" but you must remember that many of the hoses are used for :-
    The Air Pump 3
    The EGR 8
    The Dizzy has 2 x circuits.. 1 for when the air pump is running & cold start.. & the 2nd outer, for normal running..
    most of the time the EGR is blocked & inner vac' advance on the dizzy is dead/stuffed
    & the air pump only runs for the first few minutes at start up.. after that it is dead Hp..
    in short you need a vac' hose to :-
    the dizzy outer vac' diaphragm
    fuel pressure reg' thing
    charcoal can.. for emissions..
    & the cruzz control if you have it..
  1. Replies: 27
    Last Post: 09-01-2007, 01:56 PM
  2. MA61 1JZGTTE Gearbox fitting Q's
    By Rorge in forum Tech and Conversions
    Last Post: 06-11-2006, 11:19 AM
  3. Buying an MA61 (Calling all ma61 nuts)
    By Sam Red Rolla in forum Tech and Conversions
    Last Post: 17-10-2006, 05:19 AM
