fuel pressure ref shouldn't matter though as running most engines (idle / off boost) with no vac connected makes minimal change (never tried it on a CA18 though) I'd say something to do with the ECU. If it's had water go in it i'd say 99% the map has changed and is the source of your problem. Can you hook up the hand controller? did your dyno guy keep a backup copy of your settings on his laptop that you could access, or maybe ask on nissan forums for a base map? I would think that if the problem started when water entered the ECU that that is where the problem is. Anyway good luck finding the gremlin.
something to reduce the spiking voltage that killed the ECU in the first place.
