Results 1 to 15 of 24
Thread: Car still running like shit! WTF is going on?
    I see invisible people Backyard Mechanic WHITCHY's Avatar
    New South Wales
    Default Car still running like shit! WTF is going on?
    Hey guys,
    I've had the AE86 running and road legal for about 24hrs, and its already decided to pack it in.
    Its running a CA18DET, controlled by a Microtech MT8.
    The car leaks like a siv, so it looks like some water made its way down the wiring and into the ecu, I was driving down the road and the car just cut out, managed to pull over and tried to restart it and the hand controller screen just displayed black squares.
    Pulled the ecu out and took it back to my mates place, pulled it apart and found a bit of water, got onto it with the hair dryer and dried it all out. Put it back in the car and it started running fine.
    I got it back to my mates place fine, but now it won't idle, and it won't make any power, if I mash the accelerator from idle it won't rev and dies, and then there is a chronic smell of fuel, if I lightly and slowly accelerate, foot on, foot off, foot on etc. it will eventually build some revs, but it doesn't like it.
    We have checked fuel pump, injectors, spark plugs and coils, there doesn't seem to be a problem there. Found a small vaccum leak at the throttle body, sealed that back up and no change.
    Has anyone got any suggestions for things to try? Seen a similar problem? Cam timing has been suggested, so will check that out tomorrow morning.
    Thanks in advance for any help and suggestions!
    -Whitchy
    Quote Originally Posted by tomvale13
    I always feared Harold the Sexual Abstinence Girraffe or whatever the fuck that thing was in primary school - any Large African animal with that much pent up sexual frustration is the last thing you wanna confine to a small darkened caravan full of kids.
    Balloon Slayer Backyard Mechanic jimmmayyy's Avatar
    Apr 2007
    Default Re: Cars running like shit...rooted ecu?
    Check the fault codes on the ECU, if nothing then check AFM, CAS, and ECU. These things are what generally fails with ECCS Nissan motors.
    It does however sound like an AFM issue to me. If you're planning big power out of it, it might be worth while to go straight for the Z32 AFM mod.
    -jimmy
    *edit*
    Just noticed you have a Microleb.. does it have any diagnostic function?
    change ECU or plug a laptop into the ECU and see if it has any errors/issues.
    New South Wales
    Thanks for the quick replys.
    Don't have access to another MT8 with CA tune, taking it to Microtech tomorrow for repairs if they can find anything wrong with it.
    Stupid MT8 doesn't plug into a laptop, but the hand controller has a diagnostics screen, everything is checking out OK on the ecu, only error showing is cause there is no air temp sensor plugged in.
    I once had a car with a Digi 2 in it. That actually decided to change some of it's settings one time and caused it to run 'uber rich
    It was something stupid too, like an accelerator pump setting.
    This is why I don't like Microdribbles
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    CAS, is the first thought from the behaviour you describe, or some random setting change - but the fact it got wet at the same time the symptoms started...
    Toymods Club Member
    Western Aus
    mate had this shit happen
    was power fc though.
    AFM fail!
    he even plugged another one in to test and that one was fucked too ahhahah
    wa
    doesnt the microtech get rid of the AFM....?
    thought they where all internal MAP sensored. well mine is anyway...........
    New South Wales
    Ok, this is seriously getting f**king ridiculous now!
    The ECU is back, and repaired, apparently it had some burnt out earth tracks.
    We have replaced coil packs, and fuel pressure regulator, added more earths and its still being a piece of shit!
    We pulled the front timing cover off, and it looks like the exhaust cam had slipped a tooth, and the timing belt was a bit loose, fixed this up, and it has made things worse!
    If we clamp the return fuel line the car will happily rev and idle fine. Swapped the fuel pump out yestrday and still no change, it is getting good voltage.
    Going to get a fuel pressure gauge this week and get that tested.
    Has anyone got any suggestions for other things we should be looking for?
    I just can't come to terms with the fact that the same day the ECU gets wet, something else major decided to pack it in, just to fuk with me!
    Eldar/Jonothan yeah the Microtech is internal MAP, so no shitty AFM.
    Would that indicate that a fuel pressure reg isn't working properly?
    Default Re: Car still running like shit! WTF is going on?
    yah, borrow/swap pressure reg...
    New South Wales
    You'd think so, but I've tried a different one and still the same problem! Could be a crapped out one also, will know for sure once the fuel pressure gauge is hooked up. But the mechanic I spoke to said it would be unlikely, fuel pressure regulators are pretty reliable.
    Just put a cable-tie really tight around the return line and hope it holds on?
    New South Wales
    Yeah, thats how we have been clamping it, but I don't want to go driving around with it like that and risk washing the bores.
  1. Toyota BEANs, Multiplex etc
    Last Post: 14-12-2016, 06:21 AM
  2. 1NZ-FE ECU & Ignition barrel problem
    By progkamol in forum Tech and Conversions
    Last Post: 20-03-2009, 12:24 PM
  3. 4agze fault codes & diagnosis + Pulley
    By Poggy in forum Tech and Conversions
    Last Post: 01-05-2007, 10:11 AM
