Results 1 to 3 of 3
Thread: Fitting A/M oil pressure gauge to 21R-C -- Where's the sensor?
    Jan 2007
    Default Fitting A/M oil pressure gauge to 21R-C -- Where's the sensor?
    So I decided to pick up an aftermarket oil pressure gauge-- analogue, 'cause it was cheap -- and routed the pipe into the bay no problems -- and now I can't find the sensor for the oil pressure dummy light, nor can I find the secondary sensor position on my engine. I have a wiring diagram for my car issued by Toyota that doesn't seem to be correct.
    Can anyone give me an idea of where I should be looking? I've got an '82 Celica w/5 speed and 21R-C, A/C and P/S installed. And yes, I'm happy to disable the warning light. My new gauge has one anyway.
    -- Cheers,
    Neal
    PS; The diagram says it's tucked behind the thermostat -- There's a weird plug with an internal hex removal there, in about the spot that it says it's meant to be, alongside the "spare" sensor spot -in- the thermostat -- Maybe that's it? Any ideas?
    south austraila
    Default Re: Fitting A/M oil pressure gauge to 21R-C -- Where's the sensor?
    Ok... not that i would use an oil gauge with oil line... i use electric.....
    you can mod the dash to have a look a like stock dash with oil gauge...
    anyway next to the oil filter there is the oil switch... & under the filtr is the 2nd port....
    i've used both, & had oil gauge & light....
    a mate has a RA60 with 22R running both...
    Project: '82, GA61 XX
    Jan 2007
    Much appreciated! I was kinda hoping it wasn't buried under the carburettor there but so be it -- time to go spelunking.
    Cheers for the info.
  1. Saber Gauges - Oil pressure stupid reading>?!?
    By 77GZE in forum Tech and Conversions
    Last Post: 26-12-2008, 12:55 PM
  2. 2JZ-GTE Boosting Issues
    Last Post: 30-08-2008, 09:17 AM
  3. Oil Pressure Senders & JZ Series Engines
    By 82MKII in forum Tech and Conversions
    Last Post: 03-06-2007, 11:13 PM
  4. Air Fuel Gauge Installation on 1JZ-GTE
    By Danners in forum Tech and Conversions
    Last Post: 07-05-2007, 10:33 AM
