Results 1 to 15 of 21
Thread: Oil Pressure Senders & JZ Series Engines
    Junior Member Backyard Mechanic 82MKII's Avatar
    Default Oil Pressure Senders & JZ Series Engines
    Were any JZ series engines ever released with an oil pressure gauge (rather than a switch)?
    Reason for the question: my good old 5MGE & analogue instrument cluster has an oil pressure gauge, but the JZ has a switch. Unfortunately the sender unit from the 5MGE is physically too large to fit on the JZ block (threads are the same, but due to bits of the webbing on the block there just isn't enough room to make it fit). So I have two choices:
    a) get a short bit of braided hose & some couplings to 'remote mount' my existing oil pressure sender (possible but not really that nice)
    b) If the answer to my question above is yes - get one of those senders, because I know it'll fit in the tiny space toyota have allowed for it.
    Any info would b greatly appreciated.
    Thanks
    Peter
    wa
    Default Re: Oil Pressure Senders & JZ Series Engines
    can you get just an adapter to space it away from the block a little like a brass fitting
    i think all are oil light as there is not much room for an oil pres gauge sender
    i have fitted a gauge sender but u need a 45 degree brass adapter and maybe an extension
    either wway u have to pull half the shit off left hand side to get to it
    Thanks guys. I'm a little concerned about possible fatigue issues with using solid extensions (with the weight of the sender hanging off it). It seems like I'm unlikely to get a sender that fits, so a 'remote mount' of the sender seems the go.
    Peter
    Even easier. The bolt that holds the sandwich oil cooler is hollow. Unbolt. Tap that to the thread of your oil pressure gauge sender. Refit. Hook the oil pressure switch up to a bright LED so it works as a warning light. Send GT beer.
    This is how they do it on the GS300.
    GT - I think we have a winner!
    Bloody good idea and now you mention it I think I have seen some threads about doing this in the past. Good idea about using the switch as well.
    Beer for you - waiting here in WA.
    Thanks
    Peter
    or if there is a an oil cooler hanging off it thne all uneed is about $30 worth of bits from pirtek and u can put it in the oil line
    The boobs are back
    Quote Originally Posted by 82MKII
    Seconded, definetly beer waiting for you in Perth, possibly even some Margaret River red
    Quote Originally Posted by gianttomato
    FTW
    Rosewood
    you can actually buy that bolt straight from toyota. Its a direct fit.
    http://www.mkiv.com/techarticles/oil...mod/index.html
    Awesome - thanks Lance.
    Beer waiting for you in WA as well!
    Regards
    Peter
    that bolt was $60 when I checked.
    QUICKEST 1JZ'S IN OZ
    Crazy talk.
    GT FTW lol
    Yah $107 (not trade) when I checked.
    Taking it to the local engineering shop - $10 - 20 if he really wants to ping you.
    Little Creatures Pale Ale FTW. I won't burden people with the excesses of Vasse Felix or Xanadu reds....
    Western Aus
    since GT is unable, im willing to accept all free beer on his behalf, they will be treated well on the way in, not too well on way out (park/side of road/tree/etc)
    Elmo.
    By The Witzl in forum FAQ
  2. The History Of M engines
    By rob in forum Tech and Conversions
    Last Post: 25-11-2011, 08:56 PM
  3. Guide: How to build a K series motor
    Last Post: 19-10-2007, 08:43 PM
  4. F series Diff . P51 box and likely sources for GT parts.
    Last Post: 12-10-2006, 09:58 AM
