Results 16 to 26 of 26
Thread: wont change gears when switched on
    Low rep 1st year Apprentice
    Jan 2009
    Default Re: wont change gears when switched on
    thanks wilo that rules out changing clutch fluid
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    For fucks sake, this is rediculous.
    What model Commodore is it? Later ones DO use a hydraulic clutch system.
    Why is it so hard for you to construct a post that actually has any form of structure, or any real information about the car/problem?
    Jul 2008
    hey vlas,
    your oviosly new to this sort of forum thing
    this is what your message should read eg.
    1996 vs commodore 3.8 sedan, 5 speed manual trans
    problem- not engaging any gears when clutch pedal is applied...ok
    we dont give a shit what type of car it is, we'll still happy to get you out of a jam.
    if your honest up front you wont aggrivate people, fair enough...
    Nov 2007
    Vlas: Make sure car is turned off. Foot firmly on brake. put car in first gear if there is nothing in front of the car for >10meters or reverse if there is nothing on the back of the car for > 10meters. Press clutch pedal in. repeat the said process again to be sure. Always maintain a presure on the foot pedal.
    If your not cofident and have even the slightest of safety issue('s) please do not attempt the next step you can always take the car to a mechanic.
    crank engine for "1" second only. if it jerks like it shouldn't. then start by looking at the clutch cable and i believe holden's have a massive dust cover at the bottom of the bell housing, Take that off and have a look see.
    As mentioned, newer Commodores DO run hydraulic systems. VT Series 2 onwards I do believe.
    My Dead Supra...
    Quote Originally Posted by ReQuieM in the A70 Thread
    There is some serious talent in this thread for linking anything to fuckin gay sex. Its extraordinary.
    Adelaide, SA
    VS Series 2 onwards are hydraulic. Hence the need to know what 'commo' it is.
    Get a Toyota. Solved! Close thread.
    oh wow, im in this one to the end. very amusing thread A+
    my bet is on clutch cable/pedal needing adjustment, or a heap of air in the clutch fluid.
    to give a response as vague as the posts by the OP have been, your clutch is fucked.
    Adelaide, SA
    Hay guys, my car doesn't work? How do I fix it?
    Jul 2008
    Quote Originally Posted by Gavatron
    have you tried reseting the flux capacitor
    are you still using plutonium or have you upgraded to mr fusion waste disposal
    Vlas - please construct a meaningful and informative post if you wish to create a new thread.
    This thread is locked.
    Kind regards,
    Mos.
  1. Change of location
    By ddeane in forum Forum Troubleshooting & feedback
    Last Post: 03-08-2009, 05:11 PM
  2. Sourcing small metal gears
    Last Post: 19-11-2008, 04:44 PM
  3. T series rear end diff centre change guide (warning, pics!)
    Last Post: 30-05-2007, 11:57 PM
