Results 1 to 15 of 26
Thread: wont change gears when switched on
    Low rep 1st year Apprentice
    Jan 2009
    Default wont change gears when switched on
    car only changes gears when it is switched off. when it is turned on it wont change or go from neutral to first.
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    Default Re: wont change gears when switched on
    Very detailed post. Will read again. A++++
    Sounds like your clutch isn't disconnecting drive to the gearbox.
    hmm, didn't think to add a bit more detail?
    Does the clutch feel like it's working? Check clutch master reservoir for lack of fluid. Also check box for lack of fluid. If else, replace car.
    Jan 2009
    how do you solve this??
    Junior Member Grease Monkey _FNQ_rolla_'s Avatar
    1. maybe try putting your foot on the brake when changing to different gears.
    2. check the brake lights as i have heard with some of the newer cars if the brake lights do not work you can not change the gears.
    Please let us all know what the problem is.
    well thats is my 5c worth
    give that a try
    Gav
    hey is it an Auto ?
    - Clutch fork broken or bent
    - Pressure plate broken
    - Hole in clutch line
    - No Clutch fluid
    obviously to fix this you fix whatever is broken.
    Adelaide, SA
    Quote Originally Posted by _FNQ_rolla_
    give that a try
    Gav
    Just lol. That advice is not even worth 5c.
    Clutch plate may be stuck to flywheel. No fluid in clutch master. Clutch master fucked. Leak in clutch line. Fork broken. Snapped cable.
    We don;t know what car it is, so how are we to help you?
    Jan 2009
    its a manual
    Adelaide, SA
    What car is it FFS?
    Gavatron ... i was refering to auto's as in the first post there was not much info as to what the transmition was. You like everyone else, first thought of a mnual where, i thought of a new vehicle with an auto.
    like i said that was my 5c worth.
    remember we are all here to help out one another
    have a nice day
    Gav
    have a nice day
    Gav
    Realistically, you can't change gears with an auto with the car being off. So it makes sense (to me atleast) that it would be manual.
    Adelaide, SA
    And the mention of from neutral to first also was a give away.
    It's like this guy doesn't even want help. He's viewing the thread, but still not telling us what car it is.
    Jan 2009
    the car is my mates its a commo.
    i am a Backyard Mechanic WiLo's Avatar
    let me guess this right, the only posts you have made on toymods are asking for help with very minimal details initially, and then it turns out not being your car or even a toyota?
    commodores run a clutch cable still so that rules out clutch fluid.
    maybe try street commodores or just commodores?
    milk and juice come in 2L, The cheapest wines come in 5L, the finest vodka comes in 1L
  1. Change of location
    By ddeane in forum Forum Troubleshooting & feedback
    Last Post: 03-08-2009, 06:11 PM
  2. Sourcing small metal gears
    Last Post: 19-11-2008, 05:44 PM
  3. T series rear end diff centre change guide (warning, pics!)
    Last Post: 31-05-2007, 12:57 AM
