Results 16 to 17 of 17
Thread: How to eliminate (or reduce) ignition retard on A34x auto trannys?
    User Conversion King
    NWA
    Default Re: How to eliminate (or reduce) ignition retard on A34x auto trannys?
    Quote Originally Posted by cambelt
    Ok thats the fart , I remember asking about it a year or so ago but thinking it wasnt conclusive. My cressida doesnt fart at all so i dont know what ive done different.
    I did reseal the auto before it went in.
    If change my gears manually its a pretty firm shift with very little slip but if i leave it in Drive 1st to 2nd is a sloppy shift where as 2nd to 3rd good and so on.
    Can you get me yr ecu part no Brett.
    Dave
    ill chase up the part number in the next week or so.
    my auto shifts really firm and will easily chirp the tyres or break traction if you try. then again, i have 215/65/14s
    hello
    Quote Originally Posted by 131OWN
    Ignition retard occurs when the ECU see a differences (slip) between the speed sensors when this is detected the ECU pulls timing to reduce torque during the shift.
    Could this be that one of my speed sensors is stuffed then? On my rear ext housing there are two speed sensors, one mag pickup type one and one mechanical type geared wheel one. Does anyone know where I can get an A340 magpickup type one from, cause my mechanical seems fine upon checking it visually.
    I'm guessing the ECU is getting two different inputs from the speed sensors, and then defaults to the one. Could this explain things.
    Another thing I forgot to mention was, is my speedo doesn't work until after about a minute of driving around. As if it needs to warm up? If I then switch the car off and come back straight away it works fine. But if I come back say after about a hour, it doesn't work until about a minute of driving around? Could this be a speed sensor conflict, that the ECU defaults to the one that works. Doesn't really explain why the auto shifts perfectly without a working speedo and no speed sensor input to the ECU telling it when to shift??
    Is this ECU or speed sensor or both?
  1. Toyota Distributor and DLI Ignition Systems - explanation and guide
    Last Post: 14-11-2010, 01:42 AM
  2. 4AGZE has no ignition light/power auto electrician Brisbane
    By rollie69 in forum Tech and Conversions
    Last Post: 31-01-2009, 05:51 PM
  3. Ignition prob/missing 2tg - Help please auto electricans?
    By poida in forum Tech and Conversions
    Last Post: 31-10-2006, 09:08 PM
  4. Replies: 0
    Last Post: 20-07-2006, 12:18 PM
