Results 1 to 7 of 7
Thread: ST190 Corona
    Jun 2007
    Default ST190 Corona
    Hey guys i have done the searches on the forum and google for this but i cant seem to find any wiring diagrams for the ST190 corona.
    Regards
    Paul
    Default Re: ST190 Corona
    Considering that only about 3 people on here have actually owned them (& 2 of them were the Caldina wagon), that's not surprising.
    What are you trying to do?
    Jun 2007
    The cars not starting and there is a broken wire that the sparky doesn't know where it goes to so before the car gets pulled apart would like to try find what that wire does.
    Regards
    Paul
    Describe some symptoms.
    Cranks?
    tries to run but stalls?
    where is this wire?
    pics?
    Jun 2007
    Theres one black&red wire from ignition there is no power to it and we don't know where it goes. Car does start, crank, or run .
    if the car doesn't crank, you can cut down by a LOT the options of what could be wrong
    Quote Originally Posted by wcipowa
    What spec car have you got?
    The one I had was the lowest spec.
    You're talking about the wires that are on the back of the ignition switch?
    Has bypassing the switch been tried?
    ie there should be one power wire, then an accesories wire, "On" wire, "start" wire.
    Of course, the auto-lec should already know this & have tried that.
    Really, your only choice for the wiring diagrams is to google it & see if they're on other websites (doubtful), or buying them from Toyota.
    If you ask nicely, they may even give you a copy of the relevant stuff. I've got info from Holden that way before.
  1. ST190 Corona
    By wcipowa in forum Tech and Conversions
    Last Post: 02-02-2009, 09:41 AM
  2. 1GGUE into Corona info needed??
    By Shakotan_Aaron in forum Engine & Driveline Conversions
    Last Post: 16-11-2008, 06:00 PM
