Results 1 to 4 of 4
Thread: 20v leads
    Low rep Grease Monkey
    Default 20v leads
    hi guys looking of geting new leads as old ones are f*ck
    top gun and engle make 5mm leads for it ,im looking for somthing like 7-10mm
    is dere anyone that custom makes leads in sydney.
    is it worth going to 7-10mm leads
    New Zealand
    Default Re: 20v leads
    not if its stock
    please, no more PMs!
    Junior Member Backyard Mechanic KARNAGE's Avatar
    from my experience the top gun 7 and 10mm leads arent actually that good if you want a good spark get some msd 8mm leads they have heaps more spark then the 10mm topgun leads. and the msd leads are about the same as the topgun leads. they dont help much with a stock engine but if you are planning on doing more to the car later its a good start
    the silicon thickness just helps with things like cross-fire on V8's when you have high coil power.
    for anythign else it is not needed, especially if the leads are nto crossing or touching metal...
    topgun are ok.. if you replace them regularly (ie, they are a consumable)
  1. Spark plug leads...how do you make them?
    By deviant in forum Tech and Conversions
    Last Post: 12-12-2007, 02:51 PM
  2. cheap replacment 3tgt spark leads
    By Slonlo in forum Tech and Conversions
    Last Post: 10-11-2007, 07:20 AM
  3. Help - Life span of ignition leads?
    By Camryman in forum Tech and Conversions
    Last Post: 27-05-2006, 06:26 PM
