Results 1 to 7 of 7
Thread: jaycar DFA on Blacktop 20V
    Default jaycar DFA on Blacktop 20V
    Hi Guys
    Has anyone out there use the Jaycar DFA on their Blacktop 20V as I have one lying around???
    Does this make any improvement and how easy to hook up to the ecu???
    Any advise will be good....
    cheers, pkjai
    May 2006
    Default Re: jaycar DFA on Blacktop 20V
    I think there's a chance on a blacktop it'd help. They've got nasty knock detection and on aussie fuel don't perform as well as one running with an aftermarket ecu.
    Don't quote me on this, but I'd guess you'll be stopping the ecu retarding it's timing if you set it up right. The only drama is you'll need to make a circuit, as found in the MSD installation manual to send an IGF signal to the ecu (very simple to build).
    Only one way to find out
    Quote Originally Posted by pkjai
    Hi Guys
    cheers, pkjai
    They aren't hard to hook up as long as you have access to a wiring diagram.
    The only way to tune them is with a wide band air/fuel ratio meter, no point in adding a DFA unless you have access to 1 or pay for dyno tuning.
    Do the Blacktop 20V's typically run rich? Not much point fitting a DFA unless it does.
    Are the Blacktop 20V's the 1's that use the vane/flap airflow meter? If the AFM is a restriction, then you could fit a bigger 1 and use the DFA to get it running sweet again.
    Junior Member Backyard Mechanic KARNAGE's Avatar
    black top os map and typically the do run a little rich
    i forget to add that i'm running a stock blacktop ecu with quad trumpet setup and it does run slightly rich. but does this DFA works on MAP??? Where can I get information on hooking it??? and any recommendation for the dyno tune??
    I found 10hp in my GZE with one, it'll work fine with MAP, but you'll need to find the input wire from the MAP sensor and tap into that, and get someone to tune it on a dyno.
    -RM.
    mullett - how easy to hook up on the stock ecu or where can i find information in hooking it
    .... and anyone knows where its a good place to dyno tune
  1. Blacktop VS Silvertop Valves. Same??
    By Rallystanza in forum Tech and Conversions
    Last Post: 04-06-2008, 05:49 AM
  2. AE101 Silvertop + blacktop 5speed?
    By Pure-SX in forum Tech and Conversions
    Last Post: 01-03-2007, 01:51 PM
  3. Discussion: Blacktop 20v: The road beyond 200hp
    By 86er in forum Tech and Conversions
    Last Post: 18-01-2007, 10:31 PM
  4. 16v 200mm vs 20v Blacktop Lightened 212mm FLYWHEEL
    By Matt-AE86 in forum Tech and Conversions
    Last Post: 26-11-2006, 04:18 PM
  5. Jaycar Interior Light Delay Kit - Help
    By Major Clod in forum Tech and Conversions
    Last Post: 30-09-2006, 06:04 PM
