Results 16 to 23 of 23
Thread: Where is my PS fluid going?
    Default Re: Where is my PS fluid going?
    PS pump and reservoir is on opposite side from exhaust.
    Yeah I'd have thought there would be a drip or splash somewhere. I've degrease the engine so its pretty clean now. Few little engine oil leaks but not seeing any PS fluid.
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    jack the front up in the air so the the tyres are just scubbing on the ground, get the motor warmed up and then get inside cabin and work the steering like a drunk in a dodgem cart - if it's leaking you should find some new oil stains.
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    1FZ's have the same setup as the 1HZ I'm pretty sure. Driven off a gear on the crank. Can leak the same way as the 1HZ's
    Yah you are right.. Fark.. that probably explains it then.
    I better pull the pump off and suss it out.
    Quote Originally Posted by TurboRA28
    At least just drop the oil first and see if it's in there before you take the sump off...if you can't see anything, take some used oil aside and mix P/S fluid through it to see if there should be anything noticeable.
    sump off? I thought I could just unbolt the pump and replace the front seal?
    Must be going blind, sure I saw "sump" instead of "pump", probably got distracted by all the talk of it leaking into the oil.
    Just be careful when replacing the seal like i said if the shaft is worn it will be a waste of time. The pumps are easy to pull a part.
    Alex
    RA28 Turbo 18RG
    RT104 - spare toy
    BF II XR8
  1. 1jz hydraulic water pump fluid?
    By mr_mike in forum Tech and Conversions
    Last Post: 27-04-2007, 04:28 PM
  2. Bleeding brakes and fluid choice question...
    By deviant in forum Tech and Conversions
    Last Post: 25-01-2007, 05:47 PM
  3. here's a retarded question (re: power steering fluid)
    By Draven in forum Tech and Conversions
    Last Post: 22-08-2006, 05:53 PM
  4. Concentrated vs PreMixed Radiator Fluid
    By MarioM in forum Tech and Conversions
    Last Post: 17-08-2006, 03:29 PM
  5. accidently toped up power steering with brake fluid?
    By gerald1 in forum Tech and Conversions
    Last Post: 12-08-2006, 05:52 PM
