jzx81 trans tunnel will be alot bigger, as it would have been fitted with an r154 anyway,,
the mx83 trans tunnel need to be malested along the top (from the shifter hole toward the firewall....bout 30cm section,.
you also need to widen the tunnel, so give the sides of the tunnel a good pounding....
it took about 45 mins with a heavy dead blow hammer....while the car was on a hoist....if your doing it on the ground, have fun!
you may also need to cut open the shifter hole slightly....we trimmed off 5mm or so just for a nicer clearance
