To begin with - so we can help you, be a bit more specific.
When you say - bolt the A340 to the Mk2, I assume you mean how do you support the rear of the box/adapt the corona gearbox X-member? If so, it's a case of cutting/modifying the corona gearbox X-member so the mounting point lines up with the mounting point on the gearbox. If you want some pointers on doing this, put the engine and trans in, support the end of the gearbox with some rope, have a go a putting the stock X-member in (it won't line up initially), and take some pictures. Post them up and we'll give you some pointers on modifying it. Have you got the rubber mount that bolts to the A340?
As for the electronic speedo, are you referring to the electronic speed sensor? Unless you are using the factory computers for the trans and engine or an electronic speedo, you don't need to hook this up at all.
Sean
