Results 1 to 9 of 9
Thread: A340 wiring diagrams
    Default A340 wiring diagrams
    Ok, I have a home made shift box in the car and it was or still is wired up to a GA70 A340 box (stops at the plugs) and I now have a JZZ30 A340 box in the car that doesnt have any plugs so i just chopped it. Now im not the biggest fan of wiring jobs but ill give it a go if I can find the right info on these boxes. If anyone wants to come and do it for me and save me from a headache your quite welcome, there will be plenty of beer and cash just lying around doing nothing for you to take advantage of.
    RA23 1JZ VVTi 373hp - SOLD
    12.4 @ 110mph
    THE EVOROLLA 262.9hp - SOLD
    Default Re: A340 wiring diagrams
    ok ive noticed that the main shifter plug is numbered 1 - 10, its off a jzz30 soarer, would anyone know whats what? like gear 1,2,3? overdrive and convertor lock up?
    Also the two seperate plugs that are on either side of the auto, does anyone know what they are for? will i need them for the shift box?
    12.4 @ 110mph
    The ones on the side you'll find are speed related.. So either for the speedo in the dash and also if the ecu needs to know speed.
    In the other big plug the black and black/white is the inhibitor.
    Not sure of the rest sorry.
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    cool cheers, at least im getting somewhere! 8 wires to go
    12.4 @ 110mph
    Front sensor is speed... it doesn't go to the dash tho on JZZ30
    Rear not sure
    The plug with 10pins is actually the auto position switch, this is used to tell the control ECU where the shift lever is (The engine ECU has L, 2, D, R pins on it that come via this switch) ... it doesn't have the wiring for the solenoids...the wiring for the solenoid should be on another quite large plug...
    I have this pinout I traced for JZS147 Aristo A340E which looks like it is the same... you can test it with a mutlimeter anyway
    Wilbo's JZA80
    Wilbo's JZZ12
    Wilbo Cheers but unfortunately no go, my plug is different. any idea where i can get one of those diagrams for a jzz30? and possibly ga70?
    here is my plug
    12.4 @ 110mph
    You can do it yourself with a multimeter
    The bigger two pins are the P/N Switch....
    One of the others will be common, and will connect to another wire for each gear...!
    Wilbo's JZA80
    Wilbo's JZZ12
    vic
    For the shifting of gears you use the 3 wires coming out of that 3 pin plug at the rear left of the box . 3 wires = 3 solonoids , S1,S2,S3 , very easy for you.
    Dave
    Quote Originally Posted by Jordan 76
    As others said, selector switch.
    Depends how your shift box works - if it relies on a switch telling it which gear it's in, then yes, you will need this one.
    Do this to work out what is what
    Front speed sensor, NE+/NE-, rotor stops turning when overdrive is selected. Irrelevant unless factory ECU is used. There should be another one on the extension housing.
    As Dave said, solenoids. Do you need the pinout?
    Mos.
  1. Replies: 271
    Last Post: 13-11-2019, 01:49 PM
  2. AE101 Levin wiring diagrams needed, HELP!!!
    By TERRA Operative in forum Tech and Conversions
    Last Post: 06-05-2008, 07:50 PM
  3. SW20 3s-gte wiring Diagrams
    Last Post: 24-03-2008, 10:50 AM
  4. Link to wiring diagrams
    By TC1600 in forum Tech and Conversions
    Last Post: 25-02-2007, 08:06 PM
  5. 100kW 4AGE wiring diagrams
    By Hen in forum Tech and Conversions
    Last Post: 15-04-2006, 06:03 PM
