Results 1 to 6 of 6
Thread: W50 gearbox
    Jan 2009
    Default W50 gearbox
    I have a 1980 hilux 2wd RN40 with a 18 R-C with the linkages really sloppy and a suspicion the selectors are worn, I have difficulty in finding 3rd and hard to put in second while changing down. Also I would like to know if a W50 gearbox would bolt in without any modification what so ever?
    Default Re: W50 gearbox
    What gbox is in there now ?
    W40 ? or something different?
    Jan 2009
    Wouldn't have a clue as I have just bought it.I assume it is a L41,That's what is on the compliance plate!
    Hmm, never heard of an L41, so I can't help you there!
    I'm guessing it's a column shift since there was mention of linkages? In which case there would obviously be modification involved with a W50 which is floor-shift only. It will bolt straight up to the engine though provided you get one from an RA23/RA40 Celica.
    Tasmania
    W50 box will bolt straight in,use same tailshaft,clutch from the old column shift and your away.
    Oh and remember to cut a hole in the floor to accommadate the gear shift .
    Thats the only mod that is needed.
    Cheers Brett.
  1. Verifying a w58 gearbox
    Last Post: 09-10-2008, 11:39 PM
  2. gearbox noise W50
    By normo in forum Tech and Conversions
    Last Post: 26-02-2007, 10:42 PM
  3. L40 gearbox swapped for W50?
    By WDE_BDY in forum Tech and Conversions
    Last Post: 21-02-2006, 11:47 AM
