Results 1 to 7 of 7
Thread: RA28 1GGTE Engine mounts for TA23 xmember
    Toymods Club Member Backyard Mechanic auto351's Avatar
    Nov 2007
    N.S.W
    Default RA28 1GGTE Engine mounts for TA23 xmember
    Hi, just wanted some ideal on how to make the engine mounts to fit a 1GGTE into an RA28 with the TA23 cross member Installed.
    I am thinking the mounts are off the shelf with a custom adapter plate but haven't seen to much info in my searches .
    Junior Member Grease Monkey Screaminrolla's Avatar
    Default Re: RA28 1GGTE Engine mounts for TA23 xmember
    This is how i had them in mine. Custom everything using the rubber mounts that were in the car before so im not really sure what they are from
    1977 RA28 Celica 1JZGTEClick Me
    1980 Chrysler Sigma
    Consult this my Friend:
    http://stradlater.com/install_guide/index.htm
    Failing that, there's heaps of shots on my website - stradlater.com
    Woops - just realised you said Ta23 x-member. Oh well, the above is still good.
    Facebook | LinkedIn
    The old One Backyard Mechanic
    Stradlater's website gives you all the information that you need.
    Just one thing to remember. I did my conversion some 10 years ago using this guide put together by Six Works - I did not change the mountings on the xmember, rather I used the rhs engine mount on the lhs turned upside down and the lhs engine mount on the rhs turned upside down. This means you do not need the 10 mm spacers and lowers the engine enough to clear everything.
    Cheers Craig
    Try this maybe - click me
    (this is not mine, just found it while looking for parts)
    Nov 2007
    N.S.W
    thanks guys, I have A TA23 xmember like screaminrollers setup the items for sale & the other links are for a RA23 xmember..
    When I picked up my engine I got steel mounts similar those on screamers engine so I just need to find out what the rubber mounts are from?
    The steel mounts I have are 10mm thick, do these need to be so think?, the factory ones are only 3-4mm thick.
    I have a feeling the rubber mounts are off the stock 1G steel mounts, not 100% sure though.
    10mm thick is heaps, thats what mine were done with.
    1980 Chrysler Sigma
  1. Issues - 1GGTE into RA28 (yes another 1!)
    By TA-022 in forum Tech and Conversions
    Last Post: 18-09-2006, 03:20 PM
  2. 4AG(Z)E Engine mounts
    By DiZ in forum Tech and Conversions
    Last Post: 05-04-2006, 10:00 PM
  3. 1ggte Engine Problem
    By ToNkA in forum Tech and Conversions
    Last Post: 26-12-2005, 09:27 AM
