Results 1 to 15 of 17
Thread: Gasket goo on exhaust manifolds
    Default Gasket goo on exhaust manifolds
    Do you guys use / recommend hi-temp gasket goo (sealant) on exhaust manifolds, either side of the gasket?
    Don't ask what engine this is for. You don't want to know.
    Default Re: Gasket goo on exhaust manifolds
    Usually i'll just spray some hylomar on it, but you could also dare to use aviation or threebond type sealant. Generally it's not necessary though if the gaskets are already in good nick then simply making sure everything is tight is good enough.... and *always* use some hi-temp anti-seize lubricant on exhaust bolts/studs/nuts - it farks me off to no end when ppl don't
    coppermax - hi-temp silicon,
    Guys,
    Keep in mind that any sort of silicon sealant will permiate and harm/kill your 02 sensor if you have one
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    You shouldn't need anything, and if you do, I.E. if you have done it recently and it still leaked, then the goo probably won't help. If it doesn't seal with a gasket and tight nuts then probably a flange is warped/damaged and it'll never seal until you have it looked at.
    I've tried all sorts of crap to get a warped flange to seal but evrything blows out in time.
    Tim.
    before efi, i used to always use red silicon on both sides of exhaust gaskets...
    simply because it makes removing them sooo easy... no scraping offf burnt gaskets.. just peel off
    hmm, what about the sensor safe silicon? i wonder if it's still safe if it burns?
    say yes to boobs Grease Monkey mc68's Avatar
    that stuff is a god send...can use it on anything, gbox's, sumps...
    O2 sensor... lets just say that *won't* be a problem.
    oldcorollas - i like your thinking. Red sealant it is then.
    drunken escapades Conversion King fatboy13's Avatar
    its for a rotor isnt it.... haha
    watching a bunch of supraforums members try to debate something technical is like watching a bunch of retards try to fuck a doorknob...
    "Sensor Safe silicon" is a contradiction in terms
    No its not a rotor, not even close. Its got 6 cylinders.
    Forum Member Grease Monkey bbaacchhyy's Avatar
    Isn't there a hi-temp Loctite product. About the only sealants I use on my car are 515 and 567. They are the best by a mile. For ewhat I have found anyway....
    Michael B
    '84 MA61 with 7M-GTE
    Now 5sp, 5 stud,17x8" Ray's, big assed brakes and decent IC
    Better turbo in the wings as well as MAFT !!!!
    OK its done now, with the red loctite gasket goo.
    And to let the cat out of the bag... have a look:
    haha its a boat!
    Rad!
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
    Aye 'tis true...
    PS: "rad" ??? Haven't heard that in a while.
  1. 7KE and 4KE injection manifolds PICS
    Last Post: 25-09-2007, 07:48 PM
  2. 3SGTE manifolds, TRD GT supra.. now with INSIDE PLENUM pics
    Last Post: 19-11-2006, 09:17 AM
