Results 1 to 4 of 4
Thread: 4ac=22rc carby = ?????
    Junior Member Backyard Mechanic MOOKIE's Avatar
    tas
    Default 4ac=22rc carby = ?????
    hey i got a hilux carby off a mate doing the fuel injection conversion and it got me thinking.
    is it worth trying to fit it on my 4ac or will it just drown it ?
    it just seemed like a shame to have the carby sitting there and the 4ac is the only carby motor i have.
    thanks in advance
    mookie
    Default Re: 4ac=22rc carby = ?????
    Quote Originally Posted by MOOKIE
    thanks in advance
    mookie
    Only way to check, unless someone has actually tried it, would be to pull the 4ac carby off and check the bolt spacing.
    You'd probably need to make up an adaptor plate otherwise, which *may* be worth the effort.
    Even then you'll probably have to get the carb re-jetted, as it'll run way, way too rich. a 2.4L carb on a poor little 1.6 engine, you see.
    32/36 DGAV weber + adaptor plate is a more common carb swap for the 4ac, makes a notable difference.
    tas
    yeah its gunna need an adapter plate which is fine i can fab one up, but im not going to go to the effort if all it with do is set my car on fire
    You'd have to be pretty fucking clueless to do that.
    See if you can pick up a 4ac inlet manifold from a wrecker if you don't want to pull your carb off and toy around with getting it to fit. That's the big problem.
    After you manage to fit it (f you do) take the carb to a carby shop, get them to throw a more appropriate jet in, and bam, all is done, all is well, and your 4ac will provide a bit more kick in the pants.
  1. 3tc wont start please help
    By Cob604 in forum Tech and Conversions
    Last Post: 29-07-2008, 06:56 AM
  2. 4K-C carby query
    By WA_TRD_83 in forum Tech and Conversions
    Last Post: 26-03-2007, 01:01 AM
  3. 18RGU Carby and Cam Questions (long winded and a few pics)
    By floppy in forum Tech and Conversions
    Last Post: 06-01-2007, 11:25 PM
