Props to Stivo, OldCorollas and Jeffro... very interesting reads, and good technical theory/basic calculations. Also spoon, at higher RPM, the pulse time is shorter, and as such if you have the same basic exhaust, with the same gas velocity, then you will require shorter runners to be able to time that pulse, whereas for lower RPM torquey motors, you will need longer runners to time the pulse. This is not unlike the theory for radio frequency circuit boards... where you can use the high frequency of the signals to determine the lenght, width and distance between of tracks to make inductors, resistors and capacitors from a cut PCB. In general tho, the higher the frequency, the shorter the wave lenght, and so the shorter the peice of track you need to do the same job. Anyone who has done anything with RF PCBs would be able to make sense of extractor primary/secondary theory quite quickly. Also, the cost of mandrel bent exhausts compared with press bent exausts even with mass manufacture can become quite high, as they take more machine hours to build, and so you cant produce them as quickly. Because time is money, even if the materials are provided at the same cost, the machine labour time will increase, as will electricity usage. a 1c increase per car over 1,000,000 cars is $10,000 less in the companies back pocket, so the managing director misses out on his payrise, and starts firing designers... That is why they are made as cheap as possible.
). In one particular instance, the people I worked for copped the thousands of dollars of added engineering costs to replace one chip with a cheaper part - in the order of $2 versus $1.50. Big automotive manufacturers will scrabble madly to save cents.
