I believe you are totally missing the point of flow and air speed here. how much air do you think you can blow into a straw compared to a pipe of say 1" diameter. I would almost certainly guarantee that it is easier to blow air through the larger one. The link to engines here is that if an engine has to work to push exhaust gases through your exhaustand away from itself then that energy used is energy that isnt going to your wheels. A build up of exhaust at the end of the ports will provide force against other gas trying to move out and provide force against the piston which is trying to move up. A basic simile here would be blowing into a straw with the other end blocked up. Here is a basic relation to Newton who clearly states that no energy is lost but it merely transforms into another state ie an explosion exerts some force into blowing things apart, some force in the form of heat, and other parts of force in both noise and light.
With relation to turbochargers, the faster exhaust gasses move through the turbocharger the faster it comes on boost therefore making greater power.
Since we are talking about combustion engines of which heat is a by product and is linked with a decrease in performance, surely the faster heat can be taken away from the engine the better in both a performance view and another view looking at engine life. While on the topic of heat colder fuel burns better and materials become more conductive ie spark plugs and leads. Here the more heat in the engine bay, the less conductive electrical components will be and may result in such thing as poor burn and detonation.
To say that your point of view is incorrect is an understatement and it would be interesting to see where such a view could develop. Another thing to point out is that an exhaust if made smaller will reduce power, which is true, the obvious distinction to be made here i imagine would be that a larger exhaust increases power. You have also failed to mention the fact that there is a market that car manufacturers are aiming at capturing where the majority of which inside this market prefer quiet vehicles.
Maybe a dyno sheet of the same car with a larger exhaust will help clarify your theory on exhaust sizing
