Results 16 to 23 of 23
Thread: 18RG Starting troubles
    Default Re: 18RG Starting troubles
    Quote Originally Posted by RAd28
    Had a look yesterday evening, and cleaned up the terminals on the battery, the starter cable though appears pretty buggered at the starter end, the insulation has melted off for a good 5-10cm, but i remember seeing that months ago and though "I'll ahve to do something about that"... so gonna rummage through the shed for another cable.
    Airfireman 1 - I understand what your saying there, but when i say the engine is cold/warm, that's not literally refering to oil temp, when the ambiant temp is closer getting up there, around midday it's typically easy to start, but early morning in winter it was a real bastard...
    River - Headlights are dimmer at idle, but if you pick the revs up to 1500ish and they brighten up.
    Crowncustom - checked the clearances a while back, and they were pretty average, got new cams coming so will fix that up, Problem is that it's not winding over, starts easily though once it turns over once or twice...
    This part makes it sound like dieing battery. How old is it?
    Junior Member Grease Monkey Cruiser97_80's Avatar
    Tasmania
    Have you checked your ignition timing?
    Incorrect ignition timing can also cause this sympton
    1990 ST185 GT4 3SGTE
    1991 ST184 SX 3SGTE
    1991 SW20 GT 3SGTE
    1998 ST215 GTT 3SGTE
    2008 VDJ200 Sahara
    7M-GTE MX73 - As mentioned earlier, the problem has been occuring consistantly for atleast 6 months, I can only assume a dieing battery wouldn't last this long...
    Cruiser - No, to be honest it hasn't crossed my mind, but i'll be sure to put the timing light on it on the weekend, thanks for the tip...
    '77 RA28LT #2 ← 2.2L 18RG...
    Nov 2007
    Quote Originally Posted by Cruiser97_80
    As cruiser stated check your ignition timing. And the vacuum advance. Too much advance at slow engine rotation can make the engine work against itself.
    Try cranking with 1/4 throttle to reduce vacuum seen by distributor and reduce advance at start up.
    Glen
    RA28 (18RG)Members Ride
    RA40 (3TGTE)
    RA40 (18RC)
    SXA11R Rav4 Cruiser
    ACA33R Rav4 Cruiser
    "early morning in winter it was a real bastard..." = poor charging from alternator combined poor battery condition = auto sparky charges you a small fortune for parts and labour
    This could also be easily induced by poor/corroded connections and your battery is simply in a state of constant 'under-charged-ness' (Charles's new word for the day).
    So before spending any money - simply remove the various high current connections (battery terminals, chassis earth, starter B+, engine earth, Alt B+) to clean each contacting face then re-attach/re-connect with suitable tightness. Replace anything that is badly borked.
    My experience is that most electrical problems are mechanical in nature and thus able to be fixed by an owner with a rudimentary level of skill (e.g. knows which end of hammer to hold).
    Junior Member Backyard Mechanic maurice c's Avatar
    Yes we Canberra
    Which end do you actually hold, i've tried both ,wearing a flanny, ugg boots and drinking VB while working on my ute and found no noticeable difference.
    Getting your missus to help bleed the brakes isn't everybody's idea of quality time.
    ahh... the problem is that when drinking VB while working on a ute, you don't use a hammer. The tools you need are a can of petrol and some matches.
    Yes we Canberra
    "touché" chuckster, "touché"
  1. Replies: 8
    Last Post: 24-09-2006, 08:47 AM
  2. Building an Australian RA21 (18RG + TA22)
    By ace in forum Tech and Conversions
    Last Post: 04-07-2006, 09:09 AM
  3. Computer Engine Modelling, (18rg in particular)
    By jeffro ra28 in forum Tech and Conversions
    Last Post: 08-01-2006, 10:20 PM
