Results 46 to 54 of 54
Thread: Supercheap $30 Pod filter
  1. #46
    Default Re: Supercheap $30 Pod filter
    when you have the same size filter housing, more flow = bigger holes for air to go thru. it is not rocket surgery.
    any filter that is not paper (which has really small holes, but larger area to compensate), needs oil to trap the dirt particles.
    dry K&N etc and foam all flow really well.. cos they are just rock filters.
    add oil and the flow rate goes down. esp if you put too much on.
  2. #47
    Quote Originally Posted by broken22
    http://cgi.ebay.com.au/3A-RACING-POD-FILTER-VOTED-BEST-FILTER-ALL-COLOURS_W0QQitemZ200286132000QQcmdZViewItemQQptZAU _Car_Parts_Accessories?hash=item200286132000&_trks id=p3286.c0.m14&_trkparms=66%3A2|65%3A1|39%3A1|240 %3A1318
    I read a filter comparison somewhere and these have great flow and filtration.
    yep, that's the one from the AutoSalon mag review.
    IIRC the Zoom review came out with the Drift and the Apexi Power Intake filters coming out on time, pretty easilly matched on horsepower gained. Seeing the particle filterring review posted above also, I'd wager on the Apexi Power Intake filter being pretty darn good.
  3. #48
    over oiling the filters also has the potential to foul various Air Flow sensors... just one more potential headache.
  4. #49
    Like a hotwire AFM. My mate has an RB20DET and uses a blitz filter because an oiled K&N would cause a problem with his hotwire AFM.
  5. #50
    It's a damn fare bet that any filter that is of original equipment specs is going to keep the fine dust/dirt out of your engine.
    If there is a question mark about air flow thu the filter element, then manometer testing would reveal the real story.
    Best part is, it doesn't cost SFA and you won't have to be subjected to some less than impartial magazine test.
    http://autospeed.com/cms/A_107827/article.html does various manometer tests on an EF Falcon and it showed a pressure drop of 1" of water across the standard air filter element.
    1" of water or 0.036 psi.......... 2/3rds of a constipated gnats fart worth of pressure .
  6. #51
    Nov 2007
    Quote Originally Posted by KARNAGE
    they did it in the paint booth with some black dust not sure how it was done but basically they raised the air pressure on the guns until the dust would go through the filter and so on the blitz filter had the highest air pressure by far and had the least dust ressidue on the test paper on the other side. it was pretty interesting to see the reults
    Well the test on MKIV.com shows that the BLITZ filter is one of the worst, did your workshop use the blitz sus filter? The one with metal elements.
    http://www.mkiv.com/techarticles/filters_test/2/
  7. #52
    Junior Member Backyard Mechanic KARNAGE's Avatar
    the boss had a meter of some sort on the system to test how much flow was actually getting through. all though i hate the magazine the results were actually in the autosalon magazine a while back probably over a year ago, i will see if i can get the results and put them up for you, so you can see for yourself.
  8. #53
    West Australia
    why is this even being fucking discussed
    1. Buy a K&N
    2. dont look back
    close thread
  9. #54
    1. Buy a K&N
    2. dont look back
    close thread
    because K&N also have their pitfalls
    buy largest paper panel filter that will fit = end thread
  1. Sams MA61 7MGTE Conversion Guide
    Last Post: 07-07-2015, 11:12 PM
  2. 1G-GTE oil filter
    By hecate in forum Tech and Conversions
    Last Post: 21-03-2008, 07:40 PM
  3. TGP Oil filter differnces
    By TooF in forum Tech and Conversions
    Last Post: 11-03-2008, 08:42 AM
  4. Oil Filter Interchangability
    By 3sgte in forum Tech and Conversions
    Last Post: 13-03-2006, 11:35 PM
