Results 16 to 17 of 17
Thread: fuel pump problem
    Default Re: fuel pump problem
    ?? you said it was still pumping and giving good pressure?
    and that it melts the fuse but doesn7t blow it..
    it sounds like you have a short in your wiring.
    if you connect your battery, to a 10 amp fuse, then to the pump, and then back to the battery, does the fuse blow?
    maybe you get the wires on the relay mixed up?
    Perth, WA
    guys,
    after further investigation i found out that one of the pin inside my fuse holder was "partially" connected. may be due to vibrations and heat over times the wire just barely connected to the pin. i suspect the wire/pin was arching when the pump is on and heat the fuse holder and melt the fuse all together.
    now problem solved.
    thanks every one
  1. AE86/Sprinter Fuse Box - Wiring Help
    By xXxPigeonKickerxXx in forum Tech and Conversions
    Last Post: 15-11-2008, 09:46 AM
  2. Dry-sump construction
    By Billzilla in forum Tech and Conversions
    Last Post: 19-10-2007, 01:51 PM
  3. Picking Best Fuel Pump..!
    Last Post: 10-09-2007, 03:15 PM
  4. fuel pump fuse
    By japlish in forum Tech and Conversions
    Last Post: 29-01-2006, 09:32 PM
  5. Mounting fuel pump (intank)
    Last Post: 24-01-2006, 09:49 AM
