Results 1 to 14 of 14
Thread: Need a few answers for info on g series diff
    Jan 2008
    N.S.W
    Default Need a few answers for info on g series diff
    I have a g295 out of an ma70 supra and i want to install it into my lexus ls400's g 922 carrier
    will it fit considering the supra diff is a 4 pinion lsd and the ls400's diff is a 2 pinion and will i be able to swap crownwheels or would they not match up
    Default Re: Need a few answers for info on g series diff
    Quote Originally Posted by white ls
    I recently swapped the internals from a MA70 4 pinion LSD into my Cressida 2 pinion open centre housing and it was a direct fit. In your case I think it is likely it will fit however you may need to swap bearings, Check the part numbers between the supra and the ls400.
    The supra and the cressida used the exact same part numbers.
    BTW Where are you located? And the LS400 diff code doesnt make much sense.
    think he means G 292 ? (it's a 2-pinion g-series at least)
    Jan 2008
    N.S.W
    it is deffinatly a g922(g series 3.6ratio 2pinion), im located in newcastle. and the bearing numbers are different
    Axle Codes
    Nope, G922 is not a valid axle code.
    [OT] interesting that they tried to do codes for the A/B series, given the depth of argument we've had here on the lack of consistancy from toyota on theese diff codings [/OT]
    Jan 2008
    N.S.W
    my compliance plate must be wrong then yeah but thats deffinatly what it says on it and ill agree iv never found it on one of those axle code guides either
    Jan 2008
    N.S.W
    double post
    Yes, the Celsior/LS400 diff code does not exist in ANY documentation I've found.
    Surprising the aussie delivered has a G922, coz my Celsior has a G924.
    assuming the aussie codes are wrong and G92x is meant to be G29x, the 922 and 924 would be the same ratio g-series diff, but one with LSD (924) and one without (922).. can you guys verify if I'm talking out my arse?
    Jan 2008
    N.S.W
    4 means 4 pinion no lsd i beleive so it may just be the same diff with 2 more pinions dont know why but
    crap that's right, odds are lsd.
    ignore me.
    Quote Originally Posted by Draven
    ignore me.
    Noted .
    Jan 2008
    N.S.W
    i was told if the half shafts are the same then the centre should fit would that just be the outside diameter of the shaft or the flange aswell and anyone got an idea of price for putting the lsd centre only into my diff using the standard crownwheel if possible
  1. diff center upgrades for G series diff...
    By JZA70 R in forum Tech and Conversions
    Last Post: 29-10-2008, 12:22 PM
  2. RT132 Corona - T Series, diff noise?
    By bnicho in forum Tech and Conversions
    Last Post: 27-07-2006, 11:18 AM
