Results 1 to 12 of 12
Thread: "Clunk" Sound when selecting Reverse
    Nov 2007
    Default "Clunk" Sound when selecting Reverse
    Hello,
    I have a 1987 Toyota Soarer with a A340E Automatic Transmission.
    Whenever I select reverse, I hear a loud clunk and the car jerks.
    I dont know much about Automatic transmissions so I'm not sure what it could be.
    What exactly could be causing this?
    Would the condition of the transmission fluid be the cause?
    My fluid is still a red colour so must still be good.
    Any Suggestions?
    Thanks.
    Default Re: "Clunk" Sound when selecting Reverse
    have you checked the fluid level?
    Nov 2007
    Fluid level is fine.
    tail shaft bushings? freeplay in the differential?
    perth
    does it go clunk before it engage's or after ?
    Aug 2006
    success 6164
    shims for the brakes can cause this noise as well..maybe check them..
    http://www.ae82ownersclub.com/forum.php
    powered by 4agze ae82 goodness.
    Nov 2007
    Quote Originally Posted by Vios-GT_07
    Tail shaft bushings? isnt that a uni joint which is a roller bearing?
    yea that's what i meant.. uni joint thingo..
    go from reverse into D into R into D and listen for 'slack'. This will let you know if it's uni joints or diff.... Alternatly get under the car and move the shaft with you hand to 'feel' for the noise.
    Tallahassee, FL USofA
    Quote Originally Posted by Z2TT
    Hello,
    Still smells fresh?
    What about when selecting drive after reverse?
    Any difference between using the brake or E-brake?
    What is the idle RPM????????????????????????????
    Another way to check for slack joints is to cruise slowly (about 40kph) and take your foot of the accelerator and then re-apply it. If you hear a clunk then this is slack in the drive train - usually the uni-joints.
    seeyuzz
    river
    Jan 2008
    N.S.W
    with my ls400 iv been told its a flogged out gearbox mount and when reverse is selected the gearox slightly lifts, dont know how valid that suggestion is because iv never looked
  1. Hissing sound in Reverse Range.
    By Z2TT in forum Tech and Conversions
    Last Post: 11-10-2008, 03:12 AM
  2. Reverse lights dead - SV21 camry
    By ajh in forum Tech and Conversions
    Last Post: 02-10-2007, 07:58 PM
  3. 1GGTE metalic sound pinging inside engine !
    By romelan in forum Tech and Conversions
    Last Post: 27-06-2006, 01:23 AM
