Results 16 to 27 of 27
Thread: Turbo-manifold adaptor plate
    May 2008
    Default Re: Turbo-manifold adaptor plate
    1992 - JZA70 STOCK - SOLD
    Mar 2008
    inner west syd now!
    yea i just found that aswell, i would go for something like this,
    http://cgi.ebay.com.au/T2-TO-T4-TURBO-FLANGE-ADAPTER-for-INTERCOOLER-CARS_W0QQitemZ370126270021QQcmdZViewItemQQptZAU_Ca r_Parts_Accessories?hash=item370126270021&_trksid= p3286.c0.m14&_trkparms=66%3A2|65%3A1|39%3A1|240%3A 1318
    but even a 5yo can weld that up, plus i want there to be a SMOOTH transition from round to rectangle, not the way it is in my link,......which would =turbulent flow, increased heat, something that isnt effiecient!
    ill continue looking for now
    wog
    Mar 2008
    inner west syd now!
    i am coming to the conclusion that it is a t4 cold side on a T3 hot side, can anybody confirm??
    dimensions
    xhaust inlet
    4.5X5.5cm
    bolt spacing
    8.5X4.cm, middle to middle
    flange size (external)
    7x11cm
    if that helps at all.
    thanxs
    wog
    Mar 2008
    inner west syd now!
    manifold dimensions are:
    exhaust out (diameter)
    6cm
    exhaust flange
    9.2X10cm
    bolt spacing
    8x7cm
    time for a custom adapter me thinks, ill start mocking something up tonight, unless somebody can help.
    thanxs guys
    wog
    Forum Sponsor Conversion King
    those adapters are poo, if you just want 2 plates welded to some tube then fair enough but it wont flow well.
    Have you looked at the adapters i make? solid billets machined to suit the application.
    http://www.toymods.net/forums/showthread.php?t=24584
    if you want a 1off i can do it but they ain't the cheapest, i can however say that it will last forever (well, longer than the car)
    linden
    Quote Originally Posted by woggin
    thanxs
    wog
    as i said earlier, yours is a CT26 Round pattern and it needs to be converted to a T3 or GT3#, that i can 100% confirm.
    linden
    Mar 2008
    inner west syd now!
    wow man, those adapters are pure billet sex!! $250 is more than i payed for the turbo itself!!
    i guess that price would probably be less than a one off adapter for me??
    ill have a look at wat else i can come up with, thanxs linden
    wog
    Mar 2008
    inner west syd now!
    i guess i should start lookin at a ct26 to purchase, may be easier!!
    thanxs linden, will keep you in mind for future.
    wog
    Mar 2008
    inner west syd now!
    heyas again,
    i had this whack set of ideas!
    1. Get a ct26 flange plate made up, weld it directly onto the t3 flange, and machine out the 7mm odd on each side the give the t3 flange and bit more of a cirular shape....
    2. cut off the t3 flange and weld on the ct26 flange, and, do the exhaust inlet mod as written above.
    3. Buy one of Lindens custom made pure billet sex ct-gt adaptors
    4. buy a Ct26 and be done with it!
    for the first 3 options ill have to rotate the compressor housing to clear the manifold, 3rd maybe not, depending how thick the adaptor is!
    wat do you guys reckon??
    The only thing i can think of is the constant heat cycles the welds would be going through, anything else i have missed??
    wog
    why not just get an ebay manifold, they are about the same price as the adapter, sure their strength may not be the best but 1jz people use them all the time.
    RA23 - Twincharged
    JZZ20 - Daily
    TAS
    Options 1-3 pretty much remove any value the turbo has, and it's not exactly a brand name item - is this turbo really worth the effort over a CT26?
    Mar 2008
    inner west syd now!
    heyas, again
    im looking at buying a highmount 7mgte manifold, but it has a t4 flange and was wondering if i could buy a adaptor, or if it would be better off buying a t3 flange and cutting off the t4 flange and then welding on the t3??
    thoughts? ideas?
    anything will help
    thanxs
    wog
  1. turbo intake manifold design
    By IH8TEC in forum Tech and Conversions
    Last Post: 10-04-2008, 01:40 PM
  2. Replies: 3
    Last Post: 13-04-2007, 05:38 PM
