Results 1 to 15 of 17
Thread: 4age pistons
    Junior Member Backyard Mechanic KARNAGE's Avatar
    Default 4age pistons
    ok im just doing a bit of research i am building a street engine which i want to be able to run fine without a turbo and at the same time be able to take maybe 10 pound boost the next day
    my question what pistons would you recomend to use as i have a set of low comp 4agze pistons here and the static compression is to low. as when i first get the engine running i wont have the turbo on it. would the 4age small port pistons be able to handle it? i will also have a microtech lt10s running it if that helps.
    also what is the different comp ratios for all the 4age pistons?
    Sep 2008
    Default Re: 4age pistons
    A lot of people run small boost on smallport engines and seem to do quite well, I guess it is all in the tune!!
    If you want I have a set of smallport pistons you could have cheap if u please.
    The GOD HAND AW11 - sold
    oregon
    Hmmmmmm you might get yourself a set of Wiseco, or similar "high compression" pistons... and have the crowns cut down to lower compression to upper 9, or low 10. That way you'd have a slug able to produce power now, and withstand boost later... with proper management
    jmho...........
    Quote Originally Posted by oldeskewltoy
    jmho...........
    Wiseco's have a large under-dome bump so the metal is still fairly thin, so you can't machine much off the top at all. If they got rid of that silly goddamn bump and made a much flatter piston they'd be a good thing. They're useless to me how they are though and that's a pity as the rest of the piston is very nice.
    www.billzilla.org
    Toymods founding member #3
    senior backyard mechanic Grease Monkey legend's Avatar
    use the gze pistons as they will do 10psi easy with the microtech
    engine should be fine will be a bit average till the revs get up.
    other option is 8.9gze pistons and a trd 0.5 hg. would give you 9.5 or so static cr or so
    will be alot better as na and will boost fine to 10psi, if you want to up the boost alot you can change hg over...
    Past - 3 RA23's 1 TA22 - Hairdresser mobiles
    Present - Red 4age KE70 - Sideways shopping trolly
    Future - White KE70 - Grandma shopping trolly
    oregon
    Quote Originally Posted by Munki
    I like this idea........ seems well thought out...
    Bill - Ahhh I've never used the Wisecos... are the JE slugs "bumped" as well??? And then there is also Arias... again if they don't have the bump.......
    hmm interesting i did think of using them and the good thing is they have the cut out for the oil squirters as well as im using a 20valve block. does anyone know where to get a good set of the newer 4agze pistons from other then toyota? since they were charging close to 800 last time i looked
    Quote Originally Posted by KARNAGE
    My brother bought a set not long ago and they were around $400 a set from Toyota. I'd suggest trying another Toyota dealer unless the price has nearly doubled in the past 6 months?
    My KE25 thread
    yeah townsville toyota is frickon expensive for some reason even with trade discount they send you broke
    You're closer to Japan too
    My KE25 thread
    Sep 2008
    KARNAGE, would you be able to contact castle hill toyota and ask them to post it for you, or get one of the guys to pick it up for you and post to you..
    haha yeah true i am yet still it would still fly into sydney and them get road transport to townsville damn bastards lol.
    kyle yeah i have got something off them before does anyone have there number?
    Sep 2008
    (02) 8831 8831 - phone - ring this one
    1800 111 388 - free =???
    thanks heaps for that mate i will see what they reckon hopefully they can post them up to me
  1. Higher comp pistons for 4agze ?
    Last Post: 15-04-2007, 05:48 PM
  2. Light Vs heavy pistons (ie: ACL specs)
    Last Post: 14-04-2007, 10:27 AM
  3. comparing 2T and 2T-G standard pistons
    By w810sc in forum Tech and Conversions
    Last Post: 02-01-2007, 06:28 PM
