Results 1 to 6 of 6
Thread: spongy brakes
    Junior Member Backyard Mechanic Hash_ra23's Avatar
    Default spongy brakes
    hey guys.
    I've got spongy brakes in my car after i replaced the motor. I don't think its air in the brake lines as they became spongy right after the engine change, they were normal beforehand. I'm thinking maybe its a vacuum leak but i can't find any leaks.
    The brakes feel normal if i give it a pump at idle. But if i leave it for a few seconds they become spongy again. Also the idle increases a bit when i press the brakes.
    I've checked the vacuum line that goes to the booster and can't see anything wrong with it.
    cheers.
    1977 RA23 Celica -> 1ggte conversion [SOLD]
    MA70 Supra 1JZ 5speed [SOLD]
    Current: IS200 1JZ VVTI 6 speed
    Nov 2007
    Default Re: spongy brakes
    Did you use the same vacuum line for the brake booster after you did the conversion?
    is there a one way valve in the line? is it facing the correct way? (so air only goes toward the engine)
    if you pump the pedal, then hold.. does it go down? can you push brake normally once or twice after engine is turned off? or it goes hard straight away?
    What motor did you start with, and what motor did you finish with??
    To test if you vaccum setup is working correctly.
    With engine off pump up the brakes to get them hard.
    With your foot hard on the brakes start the car. If the pedal falls slighlty the vaccum assistance is working.
    Junior Member Backyard Mechanic maurice c's Avatar
    Yes we Canberra
    Check to see if theres any damage to the brake lines near the firewall or to the brake bias valve, they are easy to knock when taking an engine in or out of a car. A hole of tiny proportions could be giving you problems.
    Getting your missus to help bleed the brakes isn't everybody's idea of quality time.
    By The Witzl in forum FAQ
  2. Brake Pedal Feel...spongy
    By Koffee-Black in forum Tech and Conversions
    Last Post: 07-11-2008, 03:31 PM
  3. ma61 spongy brakes after upgrade and many bleedings
    By naten in forum Tech and Conversions
    Last Post: 23-09-2008, 08:06 PM
  4. Trouble bleeding brakes (still spongy)
    By CrUZida in forum Tech and Conversions
    Last Post: 12-09-2006, 08:30 PM
