Results 16 to 30 of 36
Thread: how much for a 2gr-fe Aurion engine?
    Default Re: how much for a 2gr-fe Aurion engine?
    Quote Originally Posted by Joshstix
    Yep the 2GR bolts straight up to an E153 to go into an MR2. IT would make for a nice cruiser dropped into an SW20.
    Wondering if it'd fit upto an ST205 box... or even an ST215 box.
    It'd solve my towing torque problem big time
    Quote Originally Posted by JP
    I've got the full 2gr Aurion manual in PDF but it's a bit too large to upload, just the engine control system section is 14mb.
    Would be interesting to see what ECU the guys with 2gr's in offroad buggies and that drag car are using.
    JP - is this what you are referring to?
    For 2GR-FE models
    • Engine Control System (13.8MB, 534 pages)
    • Engine Mechanical (19.5MB, 156 pages)
    • Fuel (3.7MB, 45 pages)
    • Emission Control (1.6MB, 23 pages)
    • Intake (432KB, 6 pages)
    • Exhaust (432KB, 5 pages)
    • Cooling (3.3MB, 36 pages)
    • Lubrication (2.4MB, 20 pages)
    • Ignition (980KB, 12 pages)
    • Starting (4.3MB, 159 pages)
    • Charging (1.9MB, 25 pages)
    • U660E Automatic Transaxle (23.5MB, 350 pages)
    • Drive Shaft (2.6MB, 36 pages)
    • Axle (1.7MB, 21 pages)
    • Suspension (5.4MB, 74 pages)
    • Tire & Wheel (2.1MB, 91 pages)
    • Brake Control (12.8MB, 472 pages)
    • Brake (23.5MB, 618 pages)
    • Parking Brake (4.6MB, 66 pages)
    • Steering Column (2.9MB, 58 pages)
    • Power Steering (6MB, 67 pages)
    • Air Conditioning (17.9MB, 283 pages)
    • Supplemental Restraint System (SRS) (15.7MB, 489 pages)
    • Seat Belt (8.9MB, 71 pages)
    • Theft Deterrent (2.7MB, 88 pages)
    • Engine Immobiliser (2.7MB, 107 pages)
    • Cruise Control (1.4MB, 47 pages)
    • Wiper & Washer (1.9MB, 29 pages)
    • Lighting (6.8MB, 156 pages)
    • Door Lock (7.5MB, 269 pages)
    • Meter (3.4MB, 86 pages)
    • Audio & Visual System (8.2MB, 236 pages)
    • Navigation (8.1MB, 222 pages)
    • Horn (640KB, 8 pages)
    • Garage Door Opener (464KB, 9 pages)
    • Windshield/Windowglass (4.3MB, 108 pages)
    • Mirror (1.2MB, 24 pages)
    • Instrument Panel (8.3MB, 66 pages)
    • Seat (8.9MB, 120 pages)
    • Engine Hood/Door (10.4MB, 76 pages)
    • Exterior Trim (6.8MB, 86 pages)
    • Interior Trim (4.2MB, 58 pages)
    • Sliding Roof (2.5MB, 65 pages)
    • Communication System (4.4MB, 125 pages)
    • Electrical Wiring Diagram Manual (6.4MB, 507 pages)
    (to get above documents, click on this link - same link as above)
    Main Page (earlier models available)
    yep, that looks to be basically identical to what I have here. That makes life much easier that it's already uploaded somewhere.
    It works fine for Lotus
    Not a patch on a Backyard Mechanic
    WA (Perth)
    Quote Originally Posted by Talasas
    That's it, it's pretty much only people who want to convert who will be chasing them. But what kind of aftermarket ECU could run it?
    The Jimco 2000 buggy, which competes in the Pro class of the Australian Off-Road Championship, is fitted with a modified twin-turbo Toyota engine that generates 600kW at the flywheel.
    The Jimco 2000 is piloted by successful Australian off-road driver, David Fellows.
    The Toyota 2GR-FE VVT-i 3.5-litre V6 engine chosen by the buggy’s owner, Peter Kittle, also powers Toyota Aurion, Tarago, new Kluger and RAV4 V6.
    The Jimco 2000 is fitted with a pair of Turbonetic turbochargers that are each rated to 450 horsepower.
    “The new 3.5-litre engine has a very strong bottom-end, with its six-bolt main steel crankshaft which we run unmodified,” Mr Kittle said.
    The engine was built by Shane Wilson, owner of Shane Competition Engine Development in Mount Gambier, South Australia.
    He fitted Pankyl H-beam billet con-rods, CP pistons and PSI valve springs, all made in the USA.
    The Toyota cylinder heads have been extensively modified including Team Kittle’s own custom camshaft profiles, and modified exhaust valves with larger valve stems.
    Sitting atop the heads is a custom-fabricated aluminium intake manifold.
    The team worked with Turbonetics in the USA to calibrate the turbochargers to the Toyota’s specifications and the spread of power desired by the Kittle team.
    The Jimco 2000 weighs 1350kg and features Fox shock absorbers with Eibach springs.
    The twin-turbo intercooled engine produces 600kW at 18psi boost in prologue trim, and 485kW at 10psi boost in race trim.
    The engine has a Motec m880 management system with an ADL Motec digital dash with full data acquisition capability, and electronic adjustable turbo boost control.
    From a Toyota Press Release...
    RA23
    1G-GZE
    WA (Perth)
    My understanding is that the Evora launched at that recent British motor show had the standard 6 speed auto 'box fitted to it, and that Lotus were 'considering' developing a manual at some later stage, but it was not confirmed at that time. Has this changed now?
    RA23
    1G-GZE
    I didn't realise that, I thought they were using a Manual gearbox.
    It's not very lotus like to have an auto... but I suppose this is a 4 seater as well, perhaps that auto was so it was more 'family friendly'.
    WA (Perth)
    Yes, 'family' has been mentioned with this car in either a Lotus press release or a journo's review of the thing. It will have child restraint anchor's in the rear, and the rear seats are suitable for kids up to about 12. It's intended role is to be a Lotus for the family man, one that the wife can drive and take the kids to school, and still be cool enough for track days on the weekend for Dad!
    RA23
    1G-GZE
    motec m8xx...... of course
    nice and cheap
    Junior Member Grease Monkey off-road's Avatar
    NT
    Team Kittle do not vary the cam timing nor do they use the drive by wire throttle.
    There is a normally aspirated one in a Jimco buggy in SA on Motec. They do not use the drive by wire . I am not sure whether they vary the cam timing.
    An Autronic sm4 will run the cams but not the throttle.
    2GR-FE 200 Killer Wasps
    Junior Member 1st year Apprentice boon280's Avatar
    Apr 2007
    S.A
    the Jimco in S.A with the 2gr-fe belongs to Rick Bramley and he uses a motec ecu and has the cams working properly and uses a commodore throttle body, I spoke with him the other week and he said that they get about 165kw at the rear wheels.
    common property market.... Witzl needs to build a 2GR SW20.
    Seen similar things with the Nagari as well, various places stating that it has a manual transaxle, other places saying it's got the 6-speed auto from the Aurion too. Also whether or not it has the supercharger as well.
    It doesn't have the Supercharger, but no doubt it shall in due course just like the Exige did.
    And I'd love to see it happen.
    If the V6 would fit easilly into the AW I would have gone that way myself but the thought of cutting and shaping the rear firewall to fit it in turned me off.
    Should slot very nicely into the SW20 though
    Could be an interesting proposition for the ZZW30 as well... sub 1000kg MR V6... hmmm
    Was referring to the Nagari for the supercharger, not the Evora.
  1. Sams MA61 7MGTE Conversion Guide
    Last Post: 07-07-2015, 11:12 PM
  2. Toyota R Engine History
  3. TG engine info!
    By MitchE in forum Tech and Conversions
    Last Post: 30-07-2010, 06:27 PM
  4. MA70 --> JZA70 Conversion
  5. Engineers Cert. Question.
    By Mk3_supra in forum Tech and Conversions
    Last Post: 07-03-2007, 10:49 PM
