Results 1 to 2 of 2
Thread: Normal/Not normal? Carby
    Junior Member Grease Monkey toylica's Avatar
    Oct 2008
    Default Normal/Not normal? Carby
    Hello
    I was just looking down the carby in my 18r-c today. I see there are two barrels... one larger, one smaller. When i pump the accelerator - i can see the fuel vapor in the throat of the larger diameter barrel.
    The large diameter barrel - when you look at it - is moist looking.
    The small diameter barrel - is not moist.... and has alot of black soot built up on it - and doesnt appear to be in use....?
    Is that normal? I have noticed at pretty low revvs & taking off low revs in 1st gear - it stutters and shudders untill it gets to about 1250 revs. Is this the problem? (only just put 2 & 2 together then....)
    I have also noticed & others have commented ... 'its running to rich' ... and the plugs are black as... What is the best way for me to find out/learn how to tune my carby?
    Thankyou
    Dave
    Default Re: Normal/Not normal? Carby
    The large barrel you speak of is called the primary the smaller one is your secondaries.
    The secondaries are controlled by vacuum but with these old carbies the diphram is usually stuffed by now and thus resulting in only your primary's only opening
    And by the sounds of it you are running rich sounds like the carby is getting to much fuel at low rpm
    Also see this thread
    http://www.toymods.net/forums/showth...ght=18rc+carby
  1. 3tc wont start please help
    By Cob604 in forum Tech and Conversions
    Last Post: 29-07-2008, 07:56 AM
  2. 4K-C carby query
    By WA_TRD_83 in forum Tech and Conversions
    Last Post: 26-03-2007, 02:01 AM
  3. 18RGU Carby and Cam Questions (long winded and a few pics)
    By floppy in forum Tech and Conversions
    Last Post: 07-01-2007, 12:25 AM
  4. 2T/ 3T carby
    By suss_slide in forum Tech and Conversions
    Last Post: 25-08-2006, 11:11 PM
  5. 2t dies when normal engine temp is reached?
    By jeffro ra28 in forum Tech and Conversions
    Last Post: 21-07-2006, 09:18 PM
