Results 1 to 5 of 5
Thread: AW11 Strut Top Bearing Replacement
    Default AW11 Strut Top Bearing Replacement
    This is 1 of those jobs I've bean meaning to do for ages, and I finally got off my arse and did 1 of them .
    It's kind of hard to see, but there are 6 spot welds evenly spaced around the bearing carrier. In this high quality photo you should be able to see that I have put a white mark on each 1. After that they were centre punched.
    [/IMG]
    Spot welds drilled with a 7mm drill bit on a drill press. The combined thickness of the 3 pieces is nearly 10mm
    [/IMG]
    Typically there will be some spot weld left un-drilled, but brute force and ignorance wins the day (read: hammer and a dolly). Careful tho, as it's easy to tear the bearing retaining piece around the hole. I just opened it up far enough to get the old bearing out.
    [IMG][/IMG]
    Default Re: AW11 Strut Top Bearing Replacement
    The bearing of failure.
    [/IMG]
    Behold! The bearing of replacement. The new bearing is a deep grove ball bearing 40x15x13. Cost less than $7 each
    [/IMG]
    Use 6mm bolts,nuts and spring washers to hold it all together. A few things to bare in mind. The pieces of the strut tops are radiused and the bolts/nuts/washers will more than likely foul on them, so a grinder with a flap disk was used to relieve the bolt heads and washers to help them sit flat. Cap head bolts would be a lot easier
    [/IMG]
    [/IMG]
    Doneski.
    Diserter Domestic Engineer
    vic
    Edit: Found the photos on the link.
    WOW! This is an old thread!
    These photos were on my old desk top that suffered from hard drive death, many years ago!
    vic
    Good idea, saved me a few bucks and if the bearing blows its an hour job to replace it.
  1. Strut bending.
    Last Post: 04-09-2007, 07:00 PM
  2. Making custom strut brace
    Last Post: 26-03-2007, 09:02 PM
  3. Legalities of modifying strut tower, or strut?
    By Fattony in forum Tech and Conversions
    Last Post: 22-01-2007, 07:16 AM
