have you tried an instrument specialist for the tach ? they would more than likely sort it out for you. get it going first i reckon. and bugger the exhaust, drop in some fluids and start the sucker !
it works on pulses from the ign system and as long as they are the same then no worries however, there are 2 more cylinders, ask the auto elec whether he modified the tach for a 6 cyl
thanks will look one up......... there is nuthin id love more then to fill it up now and fire it up......... just wanna make sure everything is good to go before i do.......that way i can get straight in it and drive it..........
2012 GT86
V6 powered 5th gen celica. Sadly moved on to build below
91 st185 aus delivered, V6 turb project,
2015 Kun26r hilux
You could try to see if a camry tacho will fit into your dash. Just take it all off carefully and you'll be able see if it can be interchanged![]()
mmm yeah that sounds like the way to go, just pull a camry tach mechanism and retrofit
just so happens that i took the instrument cluster out of the camry when i pulled it apart......
so if all else fails this will be what i will more then likely end up doin....... i dont really want to go with an aftermarket gauge....... but if i have to,,,, i have too.......
will have to check to see if the sweep of the needle is similar to that of the celica for this to work though right?
2012 GT86
2015 Kun26r hilux
You would ideally swap the face of the gauge over too, if it's approximately the same shape.
i swapped the camry tacho mechanism into my SW20. the faces are slightly different so mine shows more rev's than im actually doing (about 100rpm more at 1000 indicated and 800-900rpm more at 7000 indicated)
but it should work better than NOT doing it![]()
1992 MR2 GT turbo
2009 Lexus IS-F
Built Australia's first V6 MR2 >> Winner: "I'd Drive It" award - Toyfest '07
nice conversion look forward to seeing some vids!!!!!
i also have a Genuine MOMO boss kit to suit a ST184.. if you are intrested
The GOD HAND AW11 - sold
i am going to refrain from the rice attack with the body mods.. and odley painted parts..
+ 100000 for doing this conversion, definitly looks like it will haul arse, mostly due to the low down torque they have, would be keen to see what she ends up running down the quater.. and plus the S/C good work haha.. keep updating, and please youtube vids!!!
Originally Posted by mattysshop
thanks man...........
this is still a work in progress and will be for some time to come............all pieces will fall into place in time.....conversion in almost finished..........
and will definately be you-tube-ing any vids especially the initial start up vid.....and first drive.......cant wait.........
2012 GT86
2015 Kun26r hilux
I hope you took a photo of yourself standing in the empty engine bay.
No conversion is complete without this photo.
Very well.
You may proceed.![]()
engine is wired ...... exhaust y-pipe is in the process then almost done..............
i have also designed a new engine mount as i am not comfortable with the current one........ it is good to hold motor but stress's from running may cause some dramas.....
will keep posting with updates and any pics i can take............
i havent seen my celica for over 2 months so keen to check out all the changes...........
2012 GT86
2015 Kun26r hilux
