Results 1 to 15 of 23
Thread: 1uz oil filter types
    Default 1uz oil filter types
    I did a bit of a search and unforunately the term '1uz' results in more than a few threads, none of which are talking about oil filters..
    I need to know if there's any different types of 1uz oil filter. I need the shortest one possible as it'll be very hard to get it into the spot I have it in.
    the one that came with the motor (jap writing all over it) seems to be small enough, but I doubt I can get that one here.
    Facebook | LinkedIn
    Junior Member Grease Monkey twiztd's Avatar
    Aug 2006
    Default Re: 1uz oil filter types
    Ryco list Z418 for the UZZ30 Soarer, V8 Landcruisers and LS400s.
    Dimensions as below (http://www.rycofilters.com.au/catalo...duct/part/Z418)
    Part: Z418
    Type Oil Filter
    End Material
    Height Overall 89mm
    Inside Diameter Top
    Inside Diameter Bottom
    Outside Diameter Top
    Outside Diameter Bottom
    Seam Diameter 77.5mm
    Seal Diameter 71.2mm
    Thread 3/4-16-UNF-2B
    This should be small enough but if not on their website they also have a search by size thingo
    --> http://www.rycofilters.com.au/catalogue/dimension
    So, the thread will be the same, you just need to punch in the rough dimensions of the filter you have and she'll spit out a listing for you...
    Mike
    Now - 1988 GX81 Mark II- 7MGTE, GT35R, TiAL 44m, Microtech, 550cc injectors, R154, Xtreme clutch, LSD.... Low boost tune done = 330rwhp@1 BAR...
    Then - 1989 MX83 - The big scrap heap in the sky...
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    Genuine part number is 90915-YZZD4
    My MX73 has a genuine toyota filter that is equivalent to the Z418. Part number is at home if your interested. Its a pretty small filter.
    the D4 also fits 2jzgte that what i use, i also heard (from toyota parts guy) that the TRD equivalent fileter is even smaller (i guess that means shorter)
    wa
    the D2 is shorter than the D4 and can be used if thats what your looking for
    Montrose
    Z386 will fit, and is smaller than a 418
    this thread delivers good info
    FWIW Sideshow used to sell compact 1uz filters on his website, not much room in the hilux. Not sure what brand, or whether he still does though
    Wow, that's bucket loads of info. Thanks guys!
    Facebook | LinkedIn
    I use a RYCO Z125 which is 75mm long
    Fleetguard LF 3826 is 60mm long
    Jealousy is a curse
    AC Delco part number AC024 is pretty small aswell.
    Junior Member Grease Monkey nilprospects's Avatar
    Sep 2008
    is that a front sump 1uz with soarer filter mount in a ...??...???
    Front sump 1UZ with a 2UZ (landcruiser) filter mount in an MX73 Cressida.
    Montrose
    I've been trying to find me one of those 2UZ filter blocks for a while actually... Local wreckers don't seem to keen to separate, understandably!
  1. 1UZ into MA61 / MZ10 Guide.
    By CrUZida in forum Engine & Driveline Conversions
    Last Post: 01-09-2013, 07:27 PM
  2. 1uz oil filter locations
    Last Post: 28-03-2008, 06:46 PM
  3. Replies: 23
    Last Post: 29-04-2007, 01:18 PM
  4. Pics needed: 1uz oil filter / air con fittement
    Last Post: 11-09-2006, 03:48 PM
