Results 1 to 5 of 5
Thread: oils ain't oils
    Default oils ain't oils
    After some oil tech advice to help keep the stocky UZ together until the dry sumped monster is built.
    A bit of background. I have always run Mobile 1 0W40...until i started running slicks that is. Even with the baffled sump and shrouded pickup i was getting surge at WP from the xtra g's. I figured i needed a heavier weight oil so started using the 'motorsport' Castrol Edge 10W70.
    I still get lower oil pressure than i'd like, so rather than trying to maintain oil pressure per se, what i need is the oil that'll do the best job of bearing protection.
    From my reading it's a bit of a black art and shear strength seems more important than oil weight and the 2 need not be related?
    Any oil gurus out there care to shed some laymen wisdom
    Default Re: oils ain't oils
    i dunno much, but is the oil relatively hot or cool on the track? ie, are you runnign higher or lower viscosity than the "rated" vis?
    Still to wire up my oil temp guage but running a big oil cooler so not 'likely' i'm having any issues
    might need to move up slowly and see what happens.
    But just wondering with the baffled sump, did you put a lip on the baffle?
    Forum Sponsor Conversion King
    Dec 2006
    Put an extra oil cooler on it (or 2) and use them as a large reseviour (reducing surge problems) as such with the added benefit of cooling the oil also which will bring the oil pressures up.
    linden
  1. The real oils
    By SYC02T in forum Tech and Conversions
    Last Post: 06-11-2006, 08:28 PM
  2. oring o-ring seal material nitrile viton teflon
    By oldcorollas in forum Tech and Conversions
    Last Post: 05-11-2006, 08:13 PM
  3. Which oil for gearbox
    By draza in forum Tech and Conversions
    Last Post: 03-10-2006, 11:14 PM
  4. oils an't oils what to use in a 3s gte?????
    By sirbabblealot in forum Tech and Conversions
    Last Post: 14-02-2006, 09:26 PM
