Results 1 to 15 of 29
Thread: 1jz engine new weird problem
    Default 1jz engine new weird problem
    G'day guys.
    I bought a 1jz recently off a user here. It had been bought originally from an import shop about a month ago and sposed to have been compression tested etc. Well the thing wont turn over.
    Have tried turning it over without plugs in it and sprayed wd40 down the plug holes.
    Have taken crank pulley off
    Taken cam covers off and everything looks nice.
    Taken sump off and everything looks nice.
    Looked down spark plug holes, pistons look alrite but can't see the walls of the bores.
    The thing won't budge turning it clockwise or anticlockwise.
    what shud i do
    1977 RA23 Celica -> 1ggte conversion [SOLD]
    MA70 Supra 1JZ 5speed [SOLD]
    Current: IS200 1JZ VVTI 6 speed
    Junior Member Automotive Encyclopaedia JZA70R_92's Avatar
    May 2008
    Default Re: 1jz engine not turning over
    have you also tried it without the timing belt?? by hand
    1992 - JZA70 STOCK - SOLD
    not yet..i think you need a hex key to loosen the tensioner which i don't have....I"ll see if i can get one though. Tried turning the cams over, and they seem like they want to move as the timing belt takes slack. So i'm pretty sure its bottom end.
    So youve tried turning it over with a breaker bar on the crank or youve tried turning it over using the starter motor?
    breaker bar on crank....has no flywheel atm so can't use starter motor.
    You just undo the two 12mm bolts on the underside of the tensioner & it will fall out.
    That takes the slack off the belt.
    Was it being stored out in the weather by the previous owner?
    Quote Originally Posted by Pure_In_Sanity
    ok just did that, timing belt off...cams spin, bottom end doesnt.
    as for being stored out of the weather....i dont know, was it jordan?
    Sep 2008
    if you have taken sump off the easiest way to diagnose it would be undo a piston or 2 off the crank and see if it moves up and down just don't pull it out then at least you will know if is no rust holding it in place or not
    Tried moving it in both directions?
    Try some penetrene in the bores if its stuck solid.
    Tallahassee, FL USofA
    Which rods don't have any side play? With tension on the crank, the one or more holding it shouldn't wiggle very easily, unless its a main bearing or oil pump that's doing it.
    argh!
    Someone had put the flywheel bolts through and fouled it on the inside of the block. Only noticed they were fouling once i took the full sump off (it was a front sump). The bolts were in friggin tight too. I wonder if its gone in so far its damaged the crank.
    All that effin round putting oil down the bores for nothin!
    Jun 2008
    Default Re: 1jz engine not turning over *Fixed*
    I would be highly surprised if there is any crank damage
    Were the flywheel bolts damaged?
    Ok got another problem now.
    I just replaced the timing belt on it and was turning over by hand to check it. Well i wanted to see if its making compression at TDC so i put my finger in spark hole 1 and i cudnt feel any.
    I checked under valve covers, and the valves are closed at TDC.
    I checked cylinder 3 and it made some compression initially, then it stopped after another couple turns.
    I put all the plugs in to turn over and it turns fairly easily (like the plugs are out)
    I checked my other 1jz with BHG and I could feel compression across the cylinders except for cylinder 1.
    I am well confused.
    Default Re: 1jz engine new weird problem
    It could be at TDC on the exhaust or the intake stroke...
    A better way to check is that the marks on the cam gears and the mark on the crank pulley / lower timing belt gear if front cover and crank pulley are off line up with their marks
    Wilbo's JZA80
    Wilbo's JZZ12
  1. 4agze ae92 AFM - Complete guide - doin it the hard way
    By ONETEN in forum Engine & Driveline Conversions
    Last Post: 19-03-2012, 04:30 PM
  2. 1JZ engine temps vs 18RC engine temps
    Last Post: 12-04-2008, 08:03 PM
  3. MA70 --> JZA70 Conversion
