Results 1 to 7 of 7
Thread: Turbine Wheel Replacement QLD
    Junior Member Grease Monkey DRIFTAMK3's Avatar
    Jul 2008
    Default Turbine Wheel Replacement QLD
    Hey guys i have searched wit no luck so thought you guys might be able to help so here goes
    I am lookin at T3 T4 hybrid turbo wit biggest T4 comp housing unsure on comp AR and Turbine housing AR as yet
    also the ext gate that comes with it is an garret item and is massive and has 22psi spring in it (so that means the lowest boost it can run is 22psi am i wright??? Or is that the max)
    But downside to turbo is that there is tiny fractures in the turbine wheel now the guy i might be buying this off said he has had it inspected by a turbo specialist and he said the turbo should be good for 80 000 to 100 000k as long as it does not run high boost constantly
    so my questions are
    1. has any one had a turbine wheel replaced if so how much and where would be the best place to get one in Brizzy or on the net
    2.same with replacment wastgate springs
    if i am right about it having a 22 psi spring and if that is the lowest boost i can run that will have to go straight up
    Junior Member Grease Monkey twiztd's Avatar
    Aug 2006
    Default Re: Turbine Wheel Replacement QLD
    22psi spring means that thats the lowest point at which the gate will open. BUT, you can always put in a lighter spring...
    As for the turbo specs, i'll leave that to the others cos i dont know
    Mike
    edit~LOL@simultaneous post...
    Now - 1988 GX81 Mark II- 7MGTE, GT35R, TiAL 44m, Microtech, 550cc injectors, R154, Xtreme clutch, LSD.... Low boost tune done = 330rwhp@1 BAR...
    Then - 1989 MX83 - The big scrap heap in the sky...
    If the wastegate has a 22psi sping, then that is the lowest boost you can run.
    It doesn't look like a 'current' style GReddy gate, but springs should be available from other sources still (if they aren't available from GReddy still)
    Current gates: http://www.trust-power.com/02turbo/w...ate_valve.html
    Wilbo's JZA80
    Wilbo's JZZ12
    Jul 2008
    hey guys thanks thats wat i thought also wilbo its a garret waste gate so do you reckon GCG or garret would have them
    im even considerin just getting a whole new gate with a lighter spring if it gonna be a headphark
    also that website is in japanese man
    Oh garret, I wasn't paying attention! my bad!
    Yeah might as well try GCG, also forcefed6 (Jamie) on the forums is good at sourcing things! )
    Wilbo's JZA80
    Wilbo's JZZ12
    22psi measn it is the lowest boost it will limit to... if you use less pedal, then you will get less boost
    Jul 2008
    cheers OC for that but i think i might just do it once and do it write the plan is to get everything that will cause me grief out of the way first so once im on the road again i can actuall enjoy the car adn not worry too much
    well thats the plan anyways lol
  1. help with installing my steering wheel :o
    By gerald1 in forum Tech and Conversions
    Last Post: 30-11-2006, 03:10 AM
  2. AE86 hand hits indecator!! momo wheel
    By Adrogen in forum Tech and Conversions
    Last Post: 10-06-2006, 07:09 PM
  3. st162 wheel bearing/stub axle
    By BeRad in forum Tech and Conversions
    Last Post: 15-10-2005, 09:29 AM
  4. Replies: 4
    Last Post: 08-09-2005, 01:17 PM
