Results 1 to 15 of 18
Thread: 7MGTE not kickin over
    Default 7MGTE not kickin over
    ok guys here is the deal
    i might have bought another soarer lol
    anyway this is the deal. apparently it was running fine 2 wks ago
    it has a flat battery. went to start it and its outa petrol.
    so they put sum petrol in it
    still no kick over
    so now i found there is no spark and no injector pulse
    so i tried new ignighter and new ecu
    still nothin
    you recon it could be the dodge alarm system in it sum how immobalising it??
    Junior Member Grease Monkey Maverick's Avatar
    N.S.W.
    Default Re: 7MGTE not kickin over
    It`s a 7m, problem identified
    Mar 2008
    inner west syd now!
    ^^^^ thats really helpful,
    its quite possible that the alarm system is causing it, considering if nothing but the battery has been changed...U can try turning the alarm off and trying it again.....if not then it could be a blown fuse??
    fiddle around with the alarm, disconnect the battery, confuse it a bit, see if anything changes, reconnect if after a while, try to start it??
    try mashing the buttons on the alarm handpiece until sumthin out of the ordinary happens??
    thats all i can say to help
    wog
    Junior Member Grease Monkey DRIFTAMK3's Avatar
    Jul 2008
    wat sort of alarm is it?
    have you searched for a killswitch or a button immobilser eg under drivers seat or in the glove box etc some alarms have them fited like viper alarms etc
    also maybe try checking your earth wires from neg cable ect if there is a fryed wire or if its not earthed properly it wont crank
    good luck
    May 2008
    take battery out and rip out the under tray near the coloum barrel and re wire it to by pass the alarm just incase...pretty easy
    1992 - JZA70 STOCK - SOLD
    Junior Member Grease Monkey DoctorDubb's Avatar
    May 2006
    Kick it harder?!?!...
    When you say it doesn't kick over i am assuming it cranks but just doesn't start? or do you mean that it doesnt even crank - which may suggest dodgy starter, alarm system/immobiliser prevent starter trigger circuit, earth from engine to body non existent/broken....
    If it cranks then i would be looking at alarm system (as you said you had replaced ECU & ignitor). As GA70 said take out near steering column, normally black box and wire without alarm. Do all your other electrics work fine? - as this may suggest blown fuse. When wiring up the 1G all it took was one power wire to injectors (relay) into ECU to not be hooked up that prevented the engine from starting. This could be easily tapped into with a single point immobiliser - maybe get a wiring diagram out for wiring colours? If you get lucky the alarm wont be all black wiring
    Steve
    1977 RA28 with 1GGTE - Now Driveable! Just with speed holes and no doors
    yeh well the arlam is dodge
    its in jap writing and its a paging one cause i see an antenna thing and its got no remote
    but yeh ill see if i can bypass the alarm
    but yeh it does crank but doesnt start
    Apr 2007
    wilcannia NSW
    no spark and no injection would suggest the crankshaft position sensor is faulty. is it in the dizzy on these ? can you borrow one to test ? and yeah, fuck the alarm right off. pos things.
    Jul 2008
    7mgte run coilpacks and igniter with injector relay so no dizzy mate........
    yeh no dizzy
    so ur econ alarm?? or should i trry a new coil pack? but still the crank sensor is gettin no power so it must b sumthin else probs alarm?
    Jul 2008
    man if you cant find any killswitches/ immobilisers and you have no blown fuses
    and your plugs dont have spark
    have you checked the alternator aswell as injector box for power?
    i went out to start my supra once after three weeks of sitting and would crank over for ever but not start checked fuel
    every where i checked there was power but wouldn start
    so i chucked the battery on charge next day fired straight up just a thought
    how much charge is in the battery in volts
    also wit the coilpack connections are they all in good cond no fryed connections etc
    the bat is dead so ive got my v8 next to it running with good jumper leads on it givin it full power
    Jul 2008
    dont wanna be negative nelly but have you checked the water in the battery and made sure the cells are ok if the battery is REALY JUST DEAD then it wont start no matter how much charge is in it
    but if i got jumper leads comin str8 from a car thats runnin it gives it full charge wont it
    May 2008
    another thing is to swap the battery out of the V8? ive had issues where I had my other car beside it and it still wouldnt start by jumper leads so i swapped out the battery and she kicked into life..... alarm is quite easy as they have tapped into wires which are color coded....just a matter of reconnecting the original wires together and ditching the alarm.
  1. 7mgte power results (6 / 5mgte's welcome)
    By mux in forum Tech and Conversions
    Last Post: 16-08-2007, 06:41 PM
