cam lobe is too gradual a curve - even for a VR sensor - a sharp-edged tooth will give you a better zero-crossing point for any sensor-signal analysis.
attach a trigger wheel to the front of one of the cam chain pulleys and then shove a VR sensor thru the timing cover. Getting it aligned and with the right tooth/sensor gap will be a challenge.
It will probably have to be VR sensor as the heat from the oil will eventually kill any epoxy holding a magnet onto a trigger wheel.
Is there a reason why you need sequential injection? Unless it's for emissions compliance, i'd suggest that it's of little benefit except at idle.
