Results 16 to 24 of 24
Thread: Shock Absorber strut listing- Urgent need 300mm long
    Default Re: Shock Absorber strut listing- Urgent need 300mm long
    AE would be spoontah or fwd corolla
    EP is fwd starlet..
    they are probably underdamped for a markII
    Shock Absorber 48511-ST050 G 2 4-stage adjustable rate 3244/1049N
    from 48000-ST0B0 kit = corona4wd/celica ST205
    not sure on the ST040
    4 way adjustable ST050 from a GT4 celica ST205 seems good.. they ar eprobably made by tokico or KYB anyway... if you can fin dthem it would be cheaper probably.
    http://www.trdparts02.jp/english/parts_suskit.html
    Junior Member Domestic Engineer ill-minded's Avatar
    May 2006
    yeah the two i had in mind were the ST040 and ST050. i knew the other two were corolla/starlet based, but posted them up anyway since they fit the physical dimensions
    i guess the next issue (apart from just using the part number at toyota) is finding them as they are a particular thing for a particular TRD strut.
    i reckon tho, if you go to toyota armed with that part number, they can order it in for you.
    May 2006
    its the closest thing to fitting so its worth a shot anyway.. i expect the price to be a bit gut wrenching though haha.
    may be pleasantly surprised though
    Forum Sponsor Conversion King
    i "think" i have some short Jic damper insert at the shop but ill have to double check.
    they were removed from a set of z20 coilover so the damping would be able to cope with a heavy car but may be too harsh.
    ill see what i can find.
    linden
    West Australia
    Linden that sounds awesome let me know !!
    OC and Ill-Minded, thanks for the input ill see what i can dig up around the net in regards to purchasing them , going to toyota in perth means i pay an extra $100 - 200 just because they can charge me that as they are toyota ...
    And we haven't looked at rebuilding them yet because...?
    Wilbo's JZA80
    Wilbo's JZZ12
    To answer an earlier question you can download a gabriel catalog from here.
    body length 299mm
    shaft travel145mm
    seat section (upper hat +spacer) 35mm
    thread length 35mm
    overall length 514mm
    body dia 45mm
    shaft dia 22mm
    These were from the Front of a Z20 (JIC Coilovers) so ill let you decide if they will be too harsh or not.
    bumpstops, gland nuts, spacers and top nuts also included.
    if they sound like what you want/need then check your PM's
    Linden
  1. Guide: Coilover Conversion
    Last Post: 18-03-2007, 08:45 AM
  2. Is this usable? (MA61 strut shock)
    By Brett in forum Tech and Conversions
    Last Post: 15-10-2006, 08:21 AM
  3. Your suspension & you...
    Last Post: 23-05-2006, 07:41 AM
  4. shock absorber bolt?
    Last Post: 21-03-2006, 08:16 PM
  5. Front Shock Absorber Dimensions...
    Last Post: 18-10-2005, 12:58 PM
