yes i could read plugs but will it still read with the conventional way we normally did when burning on petrol alone?Originally Posted by jeffro ra28
i did the 10% methanol mix and running at 1.5bar at the moment. and the timing was 21deg on full retard previously. now i still dont see any knock yet when i dial up to 24deg. i see 3% knock on my datalog at 25deg. night time run i dun get any knock on 25deg.
AFR im still doing at 10.5:1 . I would like to know wat kind of timing range should i be running on that kind of boost...as its already above my 3 bar map sensor, i need to full retard well b4 i hit 2bar boost.
as for toluene i would like to try as well... will try to ask around the hardware shop in my region...
There are always limits, the bigest limiting factor i see in this case is the fuel. You can only run with so much boost, so much retard and advance timing before it all turns to shit. The only real fix is to upgrade the fuel.
