Results 1 to 8 of 8
Thread: Fuel system- 45mm Webers
    Junior Member Grease Monkey TTECelica's Avatar
    Feb 2007
    Default Fuel system- 45mm Webers
    I am in the process of putting my 2tg in my celica, i have a pair of 45mm webers and am wondering what the best way is to set up my fuel line. Ihave spoken to a few people and have gotten mixed answers.
    Basically i want to know how i should set it up with a pressure regulator?
    fuel pump - carbies- pressure reg- return line to tank?
    fuel pump- reg with a fuel return- carbies
    ^to tank
    what are peoples opinions?
    Thanks, Josh
    '74 TA 22- 2tg with massive cams!
    "Full carpeting, tinted glass, a tachometer and a Rally-style electric clock."
    Default Re: Fuel system- 45mm Webers
    Just a 1.5psi regulator between the pump and the carbies will be fine, no return needed.
    www.billzilla.org
    Toymods founding member #3
    or a pump that has limited pressure output
    Feb 2007
    1.5psi? well joey on here is running a very similar setup to mine and he recommends between 2-3psi?
    well here is the fuel pump that i have in my car at the moment, i disconnected it as i was running the standard mech pump. previous owner must have installed it so i have no idea what it is, only markings on it are 'Fuel Flo'.
    Actually i just googled it and came up with this-
    http://www2.cip1.com/ProductDetails....e=ACC-C10-5630
    it looks practically identical, internal regulator, sounds the goods. So do i not need a regulator at all?
    Thanks, Josh
    i had a "4 cyl" fuel flo pump on my single weber...
    it is either internally regulated.. or just not able to make the pressure
    shouldn't need a reg.
    Anywhere is the range of minimum 1.5 up to max 3psi is what you should be aiming for with these type of carbies. If it is indeed that pump which you posted then you wont need a regulator, if your not sure tho try and borrow one of the small fuel pressure gauges and just hook it up inline with the fuel line before the carbies and see what it reads.
    Cheers, Joey
    Mr Shabadoo.
    Daily JZX100
    Quote Originally Posted by Billzilla
    This is what i've always been told. Although i run my reg at 3psi because being a cheapy it restricts the flow too much below this and will lean out under some conditions.
    Junior Member Domestic Engineer Hurricane's Avatar
    on my 3t and my bros L18 rally motor were just runing elec pump pumps that only pump 4psi pressure max with no return, never had any troubles and its cheap and easy to do.
    cheers, dan
    * 73 KE26 - x4 Brown Wagz
    * 73 KE20 NOW 3T-TE
    * 84 KE70 Panno
    * MX83 LS1 Track Car
  1. 3tc wont start please help
    By Cob604 in forum Tech and Conversions
    Last Post: 29-07-2008, 06:56 AM
  2. Aftermarket engine management and injectors
    By benjamin in forum Tech and Conversions
    Last Post: 14-05-2006, 01:05 PM
  3. EFI fuel system
    Last Post: 15-12-2005, 04:39 PM
  4. Replies: 1
