try this [same reply to your other post]
3 pin round plug with 2 vertical pins beside each other above a horizontal pin in a "U" arrangement.
looking at the plug w/ clip at bottom. alternator plug [obviously reverse on the alternator]
top left is Ign [IG - Black/Yellow wire] +12V on Ign
top right is CHG light [L - yellow/white wire] must have load or WILL NOT charge
bottom horizontal pin is Voltage sense [S -white wire] +12V from battery via charging system.
Wires [from above] white wire is below
the large post marked B+ connects direct to battery
got nothin' on your microtec tho'
