Results 1 to 5 of 5
Thread: 4AGE odd spark issue need help.
    Jun 2008
    Elanora Q
    Default 4AGE odd spark issue need help.
    At my witz end can not start my rolla, the car has been in storage for a while. The battery is fully charged, have checked all relays, fuses etc all ok. I have power to the igniter and coil (not sure if i should have power to coil,new to this), ok here is the odd part I only get one spark when i first turn the key to crank the the motor then nothing, i am thinking the igniter or coil may be faulty any ideas on checking the ignter any feedback very much appreciated.
    Jun 2008
    Elanora Q
    Default Re: 4AGE odd spark issue need help.
    Anyone?? please
    oregon
    is this an AE86?? If this is in an AE86, or an AW11... there are diagnostic manuals online. The manuals have a series of checks you can put each component through to check function
    Ireland
    Came across this single spark problem recently on a friends car and it was throwing up code 6 :
    RPM signal. No Ne, G signal (engine revolution sensor) signal to ECU within several seconds after engine is cranked. No Ne, G signal (engine revolution sensor) signal to ECU within several seconds after engine reaches 1,000rpm. 1.Distributor circuit. 2.Distributor. 3.Starter signal circuit. 4.ECU.
    I found the white wire at the dizzy plug had broken coming out of the yellow plug after rejoining the wire the engine fired right up.
    Jun 2008
    Elanora Q
    cheers will have a look at the above sugestions thanks again
  1. Motor blown on dyno tune...??
    By The GW in forum Tech and Conversions
    Last Post: 27-01-2008, 08:25 PM
  2. 7mgte intermittantly not getting spark
    By ra65 in forum Tech and Conversions
    Last Post: 28-10-2007, 09:29 AM
  3. Bigport 4age spark problem
    By Spode in forum Tech and Conversions
    Last Post: 24-07-2006, 06:40 AM
  4. Starting issue with 4age
    By trd-st162 in forum Tech and Conversions
    Last Post: 15-07-2006, 06:45 AM
