Results 1 to 4 of 4
Thread: Horn Fuse Location in KE70
    Selangor
    Default Horn Fuse Location in KE70
    May I ask where if the KE70 has a fuse for
    its horn, and if it does, where it is located ?
    My horn gave out today. The the wireman had added
    a relay for it some time ago, which seemed to be OK
    on checking. Both horns also seemed to work fine
    on testing.
    I drive a 1981, 4K engine, Malaysian "DX" model.
    Thanks.
    Selangor
    Default Re: Horn Fuse Location in KE70
    I have managed to find the fuse located here, in the
    engine compartment's fusebox.
    Seems the hazard lights and horn share a common 10A fuse.
    But I wonder why my hazard lights are working while my
    horn is not ?
    http://www.rollaclub.com/board/index...=post&id=20253
    http://www.rollaclub.com/board/?showtopic=17042
    New Zealand
    From memory, there is an extra fuse on the horn feed below the battery (or in that area), follow the wiring and see what you find. I had a real bugger of a time finding that on a mates car a few years ago.
    Callum
    Selangor
    Thanks for the info. Will try looking for this
    extra fuse.
    My car's aircon man too had a hard time locating
    the source of the fault. The internal wiring from the
    connectors under the dashboard to the horn buttons
    worked fine. The combination horn/hazard fuse was
    alright too, and there was power supply from the
    battery's positive terminal to the horns.
    This meant there was a break in connection from the
    wiring from the relay's terminal to the horn buttons,
    which was earthed to negative.
    So he just took out an extra wire and bridged this
    gap. The horn worked after that.
    I guess it must be this second fuse you mentioned
    which burnt out and caused this break.
  1. RA23/28 with KE70 steering column and rack and pinion
    Last Post: 24-01-2017, 04:39 PM
  2. Ke70 4age
    Last Post: 09-09-2006, 02:32 AM
