Results 16 to 19 of 19
Thread: Exhuast back pressure
    Chiba
    Default Re: Exhuast back pressure
    That's right.
    Back pressure is simply a restriction to flow, and ANY restriction in an exhaust (past the restriction point at the merge) is ALWAYS a bad thing.
    Once you have performed the merge at the headers, you cannot improve performance in any way by adding an exhaust. An exhaust pipe is simply there to allow the addition of mufflers and expel the gas in the safest way (no fumes in the cabin or burns from side pipes).
    i actually learned this a while back, and i'm pretty sure OC said it... saying that though, wouldn't a straight through exhaust reduce back-pressure in the system as compared to, say, a factory muffler with its valves and maze type flow?
    Chiba
    Yep, that's correct. The stock exhaust is that restrictive, that a straight through exhaust will be better.
    You don't have to remove your exhaust for good flow, but the less restriction to flow it causes = better performance.
    Jul 2007
    Quote Originally Posted by TERRA Operative
    That's right.
    sounds about right there.
  1. 2JZ-GTE Boosting Issues
    Last Post: 30-08-2008, 09:17 AM
  2. Oil pressure question
    By aw11man in forum Tech and Conversions
    Last Post: 12-08-2008, 09:40 AM
  3. Fuel Pressure regulator, what do you guys recommend?
    By TERRA Operative in forum Tech and Conversions
    Last Post: 26-05-2008, 03:00 AM
  4. 1JZ Fuel Pressure Regulator Limits
    By beasht in forum Tech and Conversions
    Last Post: 19-04-2008, 05:17 PM
  5. 2TG Turbo Upgrade - Advice/help please
    Last Post: 22-01-2007, 10:12 PM
