Results 1 to 7 of 7
Thread: Oil pressure question
    wa
    Default Oil pressure question
    I have noticed lately that my oil pressure will sit at a certain point at say, 100kph and 3000 rpm it will be at a particlar notch on the pressure guage and maybe a little higher when engine is cooler, its a factory guage so no sure of actual psi figures.
    Then if i go upto around 5000ish rpm (in like 3rd to stay within legal speed limits), and hold it there for a little while my oil pressure will drop a little and if it were for much longer than a minute or so it would probably head back towards half way where it sits when idleing which seems a bit too low for my likeing.
    Then if i ease back to about 3000ish rpm the pressure will rise back up on the guage to its usual spot.
    Just wondering if this is normal and if its just the engine and oil getting warmer and tolerances expanding therefore giving a lower reading for that period of time?. I dont yet have an oil cooler installed.
    Or could it be the pump is on the way out and cant handle those higher rpms, not sure if it has always been like this or just that i have noticed this lately, engine is 3sge.
    Default Re: Oil pressure question
    viscosity of the oil at certain temps,
    cold oil will casue higher OP, say cold, 80psi at idle, warm is 45psi at idle,....(normal)
    holding it at 5000rpm causes the oil to get hot, and the OP will come down a bit, (normal)
    everything you have said sounds like normal operating condition,
    has the oil been changed recently? and can you access the OP release valve and clean it out?
    wa
    Yeah i changed it the other day from 10w40motul chrono to 10w50 penrite semi synthetic, because of my move to country WA i cant find motul anywhere.
    The pessure seemed to stay slightly higher under 5000rpm+ loads with the motul than with the penrite although i thought the penrite would be thicker when flogged like that being 50, it could also be that toyota gave me the larger oil filter this time.
    Dont know much about the release valve, where is it located? its a redtop 3s btw.
    i dont know the 3s that well, but id assume it would be on the front of the motor near the oil pump,
    wa
    I think i remember someone doing this http://www.niksula.hut.fi/~mdobruck/...iy/7/valve.htm
    on here a while back.
    Is this a good idea?
    Altia ER34 GTT Domestic Engineer JetspeedCamry's Avatar
    Also, take those stock guage readings with a grain of salt. There not particularly accurate.
    Kind Regards,
    Kurt.
    1998 ER34 ニッサン スカイラインGT- T
    Nov 2007
    I'd say it's probably a combination of things. Temps changing tollerances and oil visco but may also be the design of the head & block. Not all engines have sufficient oil drain holes from head back to sump and at 5000rpm for a prolonged period you're probably pumping most of your oil into the head before it can drain back to the sump. Either way, might be worth putting in a proper pressure gauge to keep an eye on it. Low oil pressure is never a fun thing.
    Glen
    RA28 (18RG)Members Ride
    RA40 (3TGTE)
    RA40 (18RC)
    SXA11R Rav4 Cruiser
    ACA33R Rav4 Cruiser
  1. Oil Pressure Senders & JZ Series Engines
    By 82MKII in forum Tech and Conversions
    Last Post: 04-06-2007, 12:13 AM
  2. Carburettor fuel pressure question.
    By haison in forum Tech and Conversions
    Last Post: 10-05-2007, 05:01 PM
  3. Brake MS sizing vs pressure question
    Last Post: 08-09-2006, 11:22 PM
  4. Aftermarket engine management and injectors
    By benjamin in forum Tech and Conversions
    Last Post: 14-05-2006, 02:05 PM
